I am a registered Autodesk student community user and have successfully downloaded AutoCAD before (through the old downloading tool). Now when I try to download through the student community free downloads page, I get a long, thin white bar with a [CLOSE] button and nothing else. Nothing seems to start automatically downloading either. What's wrong?
Solved by jessica.t. Go to Solution.
Hi @CarloBV
Did you try downloading it from the Virtual Agent as mentioned on my previous reply to you?
Thank you,
Hi, I'm from Philippines and I am facing the same problem. I can't download autocad because it seems that my country isn't authorized to download it. Please help, I really need the software right now.
Yes, cause it's the only way we can download the files in our country (Philippines)
Hi @neelromero , welcome to the Autodesk Community!
Please, disable your firewall and anti-virus programs and download the software from our Virtual Agent linked here (click on Download Links, choose product and version).
I hope this helps!
Please, try downloading from these download links:
AutoCAD Design Suite Ultimate 2015 Part I
AutoCAD Design Suite Ultimate 2015 Part II
The situation you describe strongly suggests that there is still something blocking the download and extraction of the program. Please, make sure all your anti-virus and firewall programs are completely off and that you only start the extraction process once both files have been fully downloaded.
Hi Joane,
I have the same problem. I can't download Autocad 2015, or any other version.
I'm a french student but I'm currently in Vietnam and it seems to be because of my current location.
Please can you help me? I really need to download Autocad.
Thank you very much.
Please, download the product from the Autodesk Virtual Agent linked here. Click on Download Links, select product and version and then use the serial number provided by the Education Community to activate the program.
Please accept as solution if my post fully resolves your issue, or reply with additional details if the problem persists.
I'm trying to dwnld the Nastran 2015 trial installer form http://www.autodesk.com/education/free-software/nastran, but it looks like there are no options under "choose your version" (the only option is "choose your version", as you can see in the pic attached), so I can not dwnld the sofware; no problems for other student softwares.
Thans a lot for your help
Hi @porca_paletta,
Thanks for bringing this up! We are aware of the issue and are currently investigating the root case. I'll be sure to let you know when I receive word that it's available again.
Hi I'm an architect student and I'm having trouble downloading the student version for REVIT 2015. The download finishes but instead of having the green check marks it has red X's next to the names. I was wondering if anybody could help me out please?
Hi Kevin,
Do send a screenshot of this red X's you are seeing after downloading so we can check further. Also, you can download the installation files from our Virtual Agent and once you reach the Activation page, just use the Serial # generated from the EDU Community Site.
Hi @kreber91,
The steps detailed on this solution, written by Expert Elite TravisNave, should be just what you need to get this issue fixed.
Hi @porca_paletta, you should be good to go with the Nastran download! Thanks for your patience!
I'm a Malaysian student. I'm facing a problem which is I can't download my Autocad 2014 from the student community. After I click on the 'install now' buttom, it just show up with "
Location Error - Download Request
This download is not available in some countries.
I really need the software urgently. Need help, thank you
Hello @peiny!
Did you ever get this one sorted out? If not, can you please try creating another Education Community account using a different email and try again?
I'm student from Malaysia. I'm facing a problem with downloadig Autocad 2015. Currently using windows 7.
It shows:
I really need the software urgently for my assignment. Please do give solution. thx so much
Hi @chenjiar86 and welcome to the Autodesk Community!
Please, disable your firewall and anti-virus programs and download the software from our Virtual Agent linked here (click on Download Links, choose product and version). You can then use your Education Community serial number to activate it.
