Installation & Licensing
Can't download and run Revit 2013
2 REPLIES 2
389 Views, 2 Replies
I have tried downloading and and installing Revit 2013 multiple times everytime when I try to open it gives a "Revit.exe Application Error" saying application unable to start correctly (0xc000007b).  Please help I need this for my class this semester and am already late on two projects.
2 REPLIES 2
aaronhai
Hi kmtsosie,
Welcome to Autodesk Discussion Group.
Please attempt the download via our Virtual Agent (Matt) available from our support page
**Select [Downloading and Installation] --> [Software Download Links] --> [I need to redownload my product] --> Then select the product you wish to download.
Please let us know if that works. Thank you.
Aaron Hai
TravisNave
I suspect this is a problem with your Visual C++ Redistributable.
You can find a plethora of information about this issue here:
http://usa.autodesk.com/adsk/servlet/u/gsearch/results?siteID=123112&catID=123155&id=2088334&qt=0xc0...
Good Luck!
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Administrator Productivity
