Installation & Licensing
Can't create Building Design Suite 2012 deployment!
5 REPLIES 5
1023 Views, 5 Replies
Why? is the biggest question I have about the Building Design Suite 2012 deployment.
We just received all of these cool little thumb drives with all of these wonderful programs and I cant create the network deployment.
I am using Windows 7 64bit. I get an error "The copy functions cannot be used". The Autodesk knowledge base say "To resolve this issue, create the deployment from a machine running Windows XP Professional x64 or Windows XP 32 bit editions (Professional or Home)."
So I dig up an old training pc with Windows xp 32bit on it (no xp 64bits in sight) and try again.
NOPE. Now I get the error "The system cannot open the device or file specified".
Once again I go to the Autodesk knowledge base and they say "To resolve this issue, it is recommended that you create the deployment from a machine running Windows XP Professional x64."
WHY! do I need to go back two versions of windows operating systems to create a deployment?
Does anyone out there have a solution other than sneaker net to get the software out to the users?
David L. Bratcher,Autodesk Certified Professional
Drafter / CAD Support Specialist
[smart design]sm
Luckett&Farley
Winner, Best places
to work in Kentucky, 2009, 2010 & 2011
5 REPLIES 5
TravisNave
Try copying the contents of the USB device to the local HDD and then create a deployment from there.
Autodesk Forums:
DarrenP
in reply to: TravisNave
that doesn't work either
i had to create it on a Windows Server OS
DarrenP
in reply to: DarrenP
What version windows server were you using?
Yea, I tried the copy to HDD as well withno luck
DarrenP
Server 2003 R2 Sp2 64 bit
DarrenP
cprice
I have the same problem with Revit Architecture 2013!  Revit Structure 2013 deployed fine using Windows 7 x64.
I don't have access to Windows XP x64, and WTF should I have to?  Surely there has to be a better solution?
Administrator Productivity
