Installation & Licensing
New Member
j5v55
Message 51 of 54 (1,381 Views)
Re: Can't continue autocad 2012 setup!
03-31-2012 09:55 PM in reply to: waldroae
I have the same issue here with Net Framework 4.0
I tried all methods listed above from kevin, Autodesk.
I uninstalled, tried %temp% clean up, also I tried MS cleanup_tool.exe.
Reinstalling doesn't do any help for autoCAD installation....
It is not working.  Again, it is NOT working.
Can autoDesk be more responsive?
New Member
benp87
Message 52 of 54 (1,368 Views)
04-02-2012 04:12 AM in reply to: kokobasha
Not working on my computer also, I have Windows 7 64bit
New Member
vinshas1
Message 53 of 54 (1,205 Views)
05-17-2012 01:34 AM in reply to: cannabis68
This is because .Net framework is trying to download some microsoft patches and will continue the installtion. If the windows update service is not started then the installation will fail to install. Hence enable the Windows Update service and start it.
This will solve the issue what you are facing..
New Member
vinshas1
Message 54 of 54 (1,205 Views)
05-17-2012 02:54 AM in reply to: HelenChen-Autodesk
.Net framework installation is failing to install as it is unable to contact the microsoft update server to fetch the microsoft downloads during the installation.
Solution: Enable the Windows Update service and start it manually. If the service struck during the start then reboot the machine and try to start the windows update.
Now install the Autodesk application, it will not throw any error or fails the installation.
