Installation & Licensing
CBrown31
Message 1 of 15 (270 Views)
Can't activate
270 Views, 14 Replies
12-20-2013 07:55 AM
I am high school student trying to activate Autodesk Inventor on my computer (Dell Inspiron 620s Windows 7SP1) and not having any luck. My 30 day trial has run out and when I click on the activate button all I get is the mostly blank popup window (2 radio buttons visible). I've gone through the suggestions here: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=6404339&linkID=9240617 and they don't seem to help. I can't seem to find any phone number to call for help.
jessica.t
Message 2 of 15 (256 Views)
Re: Can't activate
12-20-2013 08:58 AM in reply to: CBrown31
Hello Carter and welcome to the Autodesk Community!
Please try these solutions to help resolve your blank activation issue:
Solution One
Solution Two
Solution Three
I hope that one of these solutions works for you! If not, please respond to this post with further details.
Thank you!
Jessica Thrasher
CBrown31
Message 3 of 15 (244 Views)
Re: Can't activate
12-20-2013 10:52 AM in reply to: jessica.t
Seriously??? The first two links are to posts from 2010! After reading a few hits from a google search I've seen references to uninstall IE 9 and use IE 8 even - IE is at 11 right now. If it takes this much tweaking to install a software package I think Autodesk needs to fix something. I'm still not having any success.
CBrown31
Message 4 of 15 (232 Views)
Re: Can't activate
12-20-2013 11:17 AM in reply to: CBrown31
As for the suggestions on this link: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=6404339&linkID=9240617 #1 - I'm currently running IE11 on Win7SP1. There isn't a version of IE8 for WIN7 #2 - Not applicable IE11 #3 - Did not help #4 - Did not help #5 - Did not help (values were already set correctly) #6 - Did not help (values were already set correctly) I also tried running from an admin account - did not help. I've tried the online activation but it asks for a Product Request Code - which I guess it will give me when I can the popup to work....
jessica.t
Message 5 of 15 (230 Views)
Re: Can't activate
12-20-2013 11:20 AM in reply to: CBrown31
I understand your frustration and I apologize that the activation process has been difficult. We continue to re-use solutions from previous years as they remain as solutions and continue to assist others with the same issue.
This solution has also been popular amongst users. It was embedded in one of the other threads but I do want to be thorough.
Out of all of the material that you have read and I have provided what exactly have you done to troubleshoot? Have you tried a good old fashioned uninstall and reinstall? It would be helpful to know so we can move forward.
Thank you for working with us to resolve this issue.
Jessica Thrasher
CBrown31
Message 6 of 15 (213 Views)
Re: Can't activate
12-20-2013 12:21 PM in reply to: jessica.t
As I previously mentioned, I am running Windows 7 SP 1 (not 8 or 8.1) As for the solution link you provided, neither of them have helped. I am running IE 11 and have gone into the security options and enabled all ActiveX settings, as well as all Active Scripting settings. I have not tried to uninstall and re-install yet - Inventor was working fine while running in trial mode. !@#$!
jessica.t
Message 7 of 15 (202 Views)
Re: Can't activate
12-20-2013 01:01 PM in reply to: CBrown31
Thank you for the additional information and we appreciate that you have completed much of the troubleshooting. But I must recommend that you try rolling back your Internet Explorer to version 8.
We are aware that this is not ideal and truly is an inconvenience but after you get your activation processed you will be able to revert back to the Internet Explorer 11.
Thanks again,
Jessica Thrasher
CBrown31
Message 8 of 15 (198 Views)
Re: Can't activate
12-20-2013 01:07 PM in reply to: jessica.t
If you check the Internet Explorer Download page, there isn't a version available for Windows 7 (or 8 or 8.1)... http://www.microsoft.com/en-us/download/internet-explorer-8-details.aspx I suppose now I need to roll back my OS?
CBrown31
Message 9 of 15 (197 Views)
Re: Can't activate
12-20-2013 01:10 PM in reply to: CBrown31
I just tried to install IE 8 for Vista 64 bit and it told me IE 8 is not supported on my OS (Win 7 SP1)
CBrown31
Message 10 of 15 (171 Views)
Re: Can't activate
12-20-2013 04:32 PM in reply to: CBrown31
Since my post I have since removed IE11, then removed IE10, then removed IE9 and finally got back to IE8. This did not help. I uninstalled Inventor (and all the other AutoDesk pieces) and re-installed. Still only get a blank window with 2 radio buttons. This is ridiculous!!!!
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
