So I just purchased Maya LT 2015 and downloaded it. Going to start it up I get the same error as other threads.
"Connection Error: This error can be caused by an inaccurate time on the system clock, or by temporary system unavailability. Please check the system clock and try again."
I followed the other threads with the same problem and changed the daylight savings time, etc. It still will not work.
Hello. This type of error usually means you have an incorrect time on your machine or it is out of synch with your BIOS.
You should boot into your BIOS and check to make sure the time matches your windows setting.
Thank you for taking part in our community!
