Installation & Licensing
Can´t activate Inventor 2015
1 REPLY 1
349 Views, 1 Reply
Hello!
I can´t activate Inventor 2015, the activation screen seens without any buttons like picture.
Can someone help me?
1 REPLY 1
TravisNave
You probably should make sure IE is your default browser, to start.  There are other factors as well.
For more information on this known Autodesk Support Knowledge Base article, please follow this link:
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Registe...
Additional discussion about this issue can be found here:
http://forums.autodesk.com/t5/Installation-Licensing/Blank-Activation-Screen/td-p/2862508
That should point you in the right direction for this known issues.  Good Luck!
Autodesk Forums:
Administrator Productivity
