Hello!
I removed autocad from another pc and installed that in new pc.
But when I try to run "Product registration & activation", it says: "
The serial number you entered is not valid. Try again. (1)"
The serial no. is ok. I try to register format 000-00000000 or 00000000000
but it still saying that it's not valid?
-Mika
Is this an Upgrade or a Full Product?
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
The installtion procedure should have the option to contact Autodesk via email if you are having trouble with the SN or Registration. I have used this successfully in the past.
I asked about Upgrade in case you are upgrading a previous version. In that case you would need to enter the previous product SN to be able to install the Upgrade. I was wondering if maybe the installation sequence was looking for the previous version software SN.
