Installation & Licensing
Can't activate AutoCAD Architecture 2011
4 REPLIES 4
ericvoo
1055 Views, 4 Replies
I can't activate AutoCAD Architecture 2011 Educational on my Windows 7 64bit laptop!
Activation screen crashes as I click on "Activate".
Windows return a message saying "Autodesk component has stopped working".
After clicking the message I can't do anything with ACAD frozen but to kill process via Windows Task Manager.
What can I do to use the software?
4 REPLIES 4
TravisNave
in reply to: ericvoo
Try launching it as another user with local admin rights, or just run as Administrator.  See if it works better.  Also, you might try updating your IE and make sure it is your default browser.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
ericvoo
in reply to: TravisNave
Tried all of you mentioned, computer running windows 7 64bit with Internet explorer 10, won't work.
TravisNave
It's possible that the problem is IE10, actually.
Autodesk Forums:
ericvoo
I think so, my last attempt was install Revit 2014, and LMU crashes without fail on startup. I resorted to uninstall IE10 (before your reply) and it actually works, I don't even need to click anything to activate. It did everything on startup automatically and I received an email saying activation successful in seconds.
Administrator Productivity
