I can't activate AutoCAD Architecture 2011 Educational on my Windows 7 64bit laptop!
Activation screen crashes as I click on "Activate".
Windows return a message saying "Autodesk component has stopped working".
After clicking the message I can't do anything with ACAD frozen but to kill process via Windows Task Manager.
What can I do to use the software?
Solved by ericvoo. Go to Solution.
Try launching it as another user with local admin rights, or just run as Administrator. See if it works better. Also, you might try updating your IE and make sure it is your default browser.
Tried all of you mentioned, computer running windows 7 64bit with Internet explorer 10, won't work.
I think so, my last attempt was install Revit 2014, and LMU crashes without fail on startup. I resorted to uninstall IE10 (before your reply) and it actually works, I don't even need to click anything to activate. It did everything on startup automatically and I received an email saying activation successful in seconds.
