The serial number sent to my email account is reporting as invalid to activate the student version of autocad 2015.
Thank you for the help
Hi @hseferian,
Using the email address on file I was able to pull up you EDU Account. On the account I only found Autodesk Revit 2014.
Please log into the site again and download Autodesk AutoCAD 2015.
Reply back and let me know if you're still having issues.
Hey Joane, i re downloaded autocad 2015, the serial number still doesnt activate the program.
thank you @joane.bonghanoy
Hi @hseferian,
Manual changes were made and you should now be able to activate your Autodesk AutoCAD 2015 with the same Serial # as your Revit.
Make sure to use Product Key 001G1.
I have the same problem. The serial number sent to my email account is reporting as invalid.
Thanks for help and kind regard. Arm
Hi Arm and welcome to the Autodesk Community!
For licensing assistance please contact our Activation and Registration team directly:
1. Visit http://knowledge.autodesk.com/contactus
2. Select “Activation & Registration” or “License Management”
3. Select appropriate subtopics from the pull-down menus
4. Select “I Still Need Help” if you need personal assistance
There you can chat with a live agent or submit an email if all agents are busy. Thanks!
