Installation & Licensing
Product Support
byron.morales
Message 11 of 23 (4,027 Views)
Re: can't activate autocad 2014(student version)
09-25-2013 02:22 PM in reply to: margea370
Hello Margea,
Please try the following. Close all programs then:
1. Rename the following file by adding a .bak extension at the end of the filename.
   Windows XP    C:\Documents and Settings\All Users\Application Data\FLEXnet\adskflex_*_tsf.data
   Vista/Windows 7
   C:\ProgramData\FLEXnet\adskflex_*_tsf.data
(note this is a hidden file and you might need to enable show hidden files under folder options)
This file contains all activations for all 2010 and newer Autodesk products.  You will need to re-register all your products if this file is renamed/deleted.
2. Restart AutoCAD and it will automatically re-register via Register Today and it will start up as expected.   A new adskflex_*_tsf.data file will be created when you re-register your product.
If you are prompted for manual activation please contact usat 1-800-551-1490 press 1 for English and press 1 again for StandAlone.
If the issue persist after performing the above steps please review the following knowledge base article poreviosuly shared by Travis on an earlier post Reply:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=21825687&linkID=12305695
Let us know the results.
Byron Morales
Product Support
dembkod
Message 12 of 23 (4,025 Views)
09-25-2013 02:57 PM in reply to: margea370
margea370,
Hello. Your blank screen is likely a result of having Internet Explorer 10 installed. Uninstall it.
  1. In the Windows Control Panel, go to Programs and Features
  2. Click Turn Windows features on or off
  3. Uncheck the Internet Explorer 10 box and click "OK". Let the process run
  4. After the system finishes processing, reboot the machine
  5. In the Windows Control Panel, go to Programs and Features
  6. Click "View Installed Updates"
  7. Locate the update for Internet Explorer 10 and select it and click "Uninstall" at the top of the screen.
  8. Let the process complete and reboot.
Thank you for taking part in our community!
David Dembkoski
Member
margea370
Message 13 of 23 (4,015 Views)
09-25-2013 05:42 PM in reply to: byron.morales
Thank you for information Byron,
I checked for C:\ProgramData\FLEXnet\adskflex_*_tsf.data and could not find this exact file. How should I re-register my products?
Member
margea370
Message 14 of 23 (4,009 Views)
09-25-2013 06:22 PM in reply to: dembkod
Thank you David!
Autocad activated itself and everything works well now!
Member
RaymondDanny8051
Message 15 of 23 (3,974 Views)
09-26-2013 12:45 PM in reply to: 041314855
I tried to do as suggested, but there is no "FLEXnet\adskflex_*_tsf.data" in the folder C\ProgramData.
I am using Windows 7.
Do you have any other suggestions?
New Member
goutham149
Message 16 of 23 (3,606 Views)
11-04-2013 01:42 AM in reply to: margea370
i am facing the same problem what to do
Member
glenobie
Message 17 of 23 (3,561 Views)
11-06-2013 04:36 PM in reply to: goutham149
Tried all posted solutions with no effect.
Member
glenobie
Message 18 of 23 (3,551 Views)
11-06-2013 05:31 PM in reply to: glenobie
BTW, I'm trying to get the licensing window on the screen for 3ds Max. I get the serial number window, and I get it to send me an activation code, but I never get a window for entering the activation code. Instead, I just get the serial number window to pop up again.
Customer Service
joane.bonghanoy
Message 19 of 23 (3,544 Views)
11-06-2013 06:39 PM in reply to: glenobie
Glen,
Please send me a Private Message (click on my joane.bonghanoy profile name and then “Send this user a private message”) with your Serial Number and a screenshot of the error so I can check on my end.
Joane Bonghanoy
New Member
maisaid
Message 20 of 23 (1,418 Views)
04-07-2014 07:52 AM in reply to: 041314855
hi. i have the same issue i cant activate my autocad licesne it gives me a blank screen or two buttons. i unistalled internet explorer and i also unistalled autocad altogether and downloaded it again. still nothing. please help
