Dear Sir / Madam,
We are trying reinstall the autocad autodesk 2013 version,due to Hard disk damage and we are not able to use the auto desk componennt to transfer the license to autodesk server to park over there for the "utility license transfer" is malfunction ,due to we did it from the bad sector hard disk.
however we decide to change the new hard disk and try reinstall the autodesk autocad but not success.
Thus,
we got 2 CD ,the 1st cd is autocaD 2013 with serial number , the 2nd cd with autocad 2013 label upgrade version without serial number.
may i know which CD should i use to install. previously we are using the upgrade CD to install , now the old hard disk has been spoilt due to bad sector.
however for this time I'm using the 1st cd to install autocaD 2013 with serial number entered but i fail to activate online it show serial number invalid error, should i run install using 2nd cd as well? hope you can help reply as soon as possible
thanks.
Hi Ang88 and welcome to the forums,
Do Drop me a personal message (Click on my muhammad.farhan.abdul.manan profile name and then send this user a private message) with the following details:
Serial number(s)
Request code / Host Name & Host ID
Company name (if license is registered to an organization)
or contact our License Assistance Team for direct support.
hi may i know how to check host name / host ID. request code it is the one prompt one the autocad screen,that when going to do activation right? thx
Hello ang88
You may refer to the following link to find out more - How to find your Host Name and Physical Address
We need the Host Name and Host ID only for Networked licenses.
Yes the request code is the one shown on the activation screen when you try to activate the software. If your license is for Standalone, please refer to this link - How to find your request code
