Installation & Licensing
Can't activate AutoCAD 2010
1 REPLY 1
RICHARDRUTLAND2761
312 Views, 1 Reply
It says the serial no. is invalid.
1 REPLY 1
That's because it most likely is.  The 2010 product has been retired under Subscription.  You likely have a 2014 product if it is still current.  Otherwise, your most current upgraded version (if and when Subscription lapsed) is the version you can activate.  That could be 2011, 2012, or 2013 in that case.
Autodesk Forums:
Administrator Productivity
