Hi Guys,
i have installed Revit2014 (& AutoCAD 2014) on a win7/64 - 8gb machine
the user on his current project still need to work on Revit2013
i did try to install revit2013, setup starts but stuck there (initializing....)
Net Framework 4.5 is installed
what could be the reason?
thanks in advance
Moshe
It could be Autodesk 360/Sync or .NET. I would remove them from the control panel and try the install again.
David hi,
it was a deplyment installation so there was a need to adjust the depoly setup and it worked.
thank you very much
Moshe
