Installation & Licensing
Can not install Revit 2013 on my new laptop
3 REPLIES 3
2103 Views, 3 Replies
I just bought a new Dell laptop with i-7. I tried to install Revit 2013 on it, always stoped at 5 of 8 remaining.
Here is the log file, please help!
2012/10/20:20:07:00 david DAVID-LAPTOP === Setup started on DAVID-LAPTOP by david === 2012/10/20:20:07:00 david DAVID-LAPTOP Launch 2012/10/20:20:07:00 david DAVID-LAPTOP CommandLine /url "http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/Autodesk_Revit_2013_English_Win_32_64bit_w..." /SN 900-32782528 /PK 829E1 /student /skipEULA /akamai /auth  /sid   2012/10/20:20:11:36 david DAVID-LAPTOP === Setup ended ===
2012/10/20:23:02:27 david DAVID-LAPTOP === Setup started on DAVID-LAPTOP by david === 2012/10/20:23:02:27 david DAVID-LAPTOP Launch 2012/10/20:23:02:27 david DAVID-LAPTOP CommandLine /url "http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/Autodesk_Revit_2013_English_Win_32_64bit_w..." /SN 900-32782528 /PK 829E1 /student /skipEULA /akamai /auth  /sid   2012/10/20:23:02:29 david DAVID-LAPTOP === Setup ended ===
2012/10/20:23:02:28 david DAVID-LAPTOP === Setup started on DAVID-LAPTOP by david === 2012/10/20:23:02:28 david DAVID-LAPTOP Launch 2012/10/20:23:02:28 david DAVID-LAPTOP Download Skipped SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/SET... 2012/10/20:23:02:29 david DAVID-LAPTOP PageOpen LaunchDialog   2012/10/20:23:03:51 david DAVID-LAPTOP PageOpen LicenseDialog   2012/10/20:23:03:51 david DAVID-LAPTOP PageOpen ProductInfoDialog   2012/10/20:23:03:51 david DAVID-LAPTOP PageOpen ProductSelectionDialog2   2012/10/20:23:04:03 david DAVID-LAPTOP PageOpen FullProgressDialog   2012/10/20:23:04:04 david DAVID-LAPTOP Download Skipped VCREDIST2005X86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/VCR... 2012/10/20:23:04:04 david DAVID-LAPTOP Installing Microsoft Visual C++ 2005 Redistributable (x86): C:\Autodesk\WI\Autodesk Revit 2013\3rdParty\x86\VCRedist\2005\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\david\AppData\Local\Temp\vcredist_x86_2005.log"" " 2012/10/20:23:04:05 david DAVID-LAPTOP Install Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1603 2012/10/20:23:04:07 david DAVID-LAPTOP PageOpen InstallCompleteDialog   2012/10/20:23:05:00 david DAVID-LAPTOP === Setup ended ===
2012/10/20:23:09:35 david DAVID-LAPTOP === Setup started on DAVID-LAPTOP by david === 2012/10/20:23:09:35 david DAVID-LAPTOP Launch 2012/10/20:23:09:35 david DAVID-LAPTOP CommandLine /url "http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/Autodesk_Revit_2013_English_Win_32_64bit_w..." /SN 900-32782528 /PK 829E1 /student /skipEULA /akamai /auth  /sid   2012/10/20:23:09:38 david DAVID-LAPTOP === Setup ended ===
2012/10/20:23:09:36 david DAVID-LAPTOP === Setup started on DAVID-LAPTOP by david === 2012/10/20:23:09:36 david DAVID-LAPTOP Launch 2012/10/20:23:09:37 david DAVID-LAPTOP Download Skipped SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/SET... 2012/10/20:23:09:38 david DAVID-LAPTOP PageOpen LaunchDialog   2012/10/20:23:10:49 david DAVID-LAPTOP PageOpen LicenseDialog   2012/10/20:23:10:49 david DAVID-LAPTOP PageOpen ProductInfoDialog   2012/10/20:23:10:49 david DAVID-LAPTOP PageOpen ProductSelectionDialog2   2012/10/20:23:11:07 david DAVID-LAPTOP PageOpen FullProgressDialog   2012/10/20:23:11:07 david DAVID-LAPTOP Download Skipped VCREDIST2005X86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/VCR... 2012/10/20:23:11:08 david DAVID-LAPTOP Installing Microsoft Visual C++ 2005 Redistributable (x86): C:\Autodesk\WI\Autodesk Revit 2013\3rdParty\x86\VCRedist\2005\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\david\AppData\Local\Temp\vcredist_x86_2005.log"" " 2012/10/20:23:11:09 david DAVID-LAPTOP Install Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1603 2012/10/20:23:11:10 david DAVID-LAPTOP PageOpen InstallCompleteDialog   2012/10/20:23:14:19 david DAVID-LAPTOP === Setup ended ===
2012/10/20:23:28:50 david DAVID-LAPTOP === Setup started on DAVID-LAPTOP by david === 2012/10/20:23:28:50 david DAVID-LAPTOP Launch 2012/10/20:23:28:50 david DAVID-LAPTOP CommandLine /url "http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/Autodesk_Revit_2013_English_Win_32_64bit_w..." /SN 900-32782528 /PK 829E1 /student /skipEULA /akamai /auth  /sid   2012/10/20:23:28:53 david DAVID-LAPTOP === Setup ended ===
2012/10/21:17:02:54 david DAVID-LAPTOP === Setup started on DAVID-LAPTOP by david === 2012/10/21:17:02:54 david DAVID-LAPTOP Launch 2012/10/21:17:02:59 david DAVID-LAPTOP === Setup ended ===
2012/10/21:17:21:33 david DAVID-LAPTOP === Setup started on DAVID-LAPTOP by david === 2012/10/21:17:21:33 david DAVID-LAPTOP Launch 2012/10/21:17:21:36 david DAVID-LAPTOP === Setup ended ===
2012/10/21:17:21:34 david DAVID-LAPTOP === Setup started on DAVID-LAPTOP by david === 2012/10/21:17:21:34 david DAVID-LAPTOP Launch 2012/10/21:17:21:36 david DAVID-LAPTOP PageOpen LaunchDialog   2012/10/21:17:21:45 david DAVID-LAPTOP PageOpen LicenseDialog   2012/10/21:17:21:49 david DAVID-LAPTOP PageOpen ProductSelectionDialog2   2012/10/21:17:21:59 david DAVID-LAPTOP PageOpen FullProgressDialog   2012/10/21:17:22:00 david DAVID-LAPTOP Installing Network License Manager:  ALLUSERS=1 INSTALLDIR="C:\Program Files\Autodesk\Autodesk Network License Manager\"  ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Revit_2013_English_Win_32bit-64bit\" INSTALLDIR="C:\Program Files\Autodesk Network License Manager\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/21:17:22:00 david DAVID-LAPTOP Install Network License Manager Failed Failure is ignored, Result=1618 2012/10/21:17:22:00 david DAVID-LAPTOP Installing Autodesk CAD Manager Tools:   INSTALLDIR="C:\Program Files\Autodesk\Autodesk CAD Manager Tools\"  ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Revit_2013_English_Win_32bit-64bit\" INSTALLDIR="C:\Program Files\Autodesk\CAD Manager Tools\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/21:17:22:00 david DAVID-LAPTOP Install Autodesk CAD Manager Tools Failed Failure is ignored, Result=1618 2012/10/21:17:22:00 david DAVID-LAPTOP Installing Revit Software Development Kit: C:\Autodesk\Autodesk_Revit_2013_English_Win_32bit-64bit\Utilities\SDK\RevitSDK.exe -d"C:\Revit SDK 2013" 2012/10/21:17:22:31 david DAVID-LAPTOP Install Revit Software Development Kit Succeeded  2012/10/21:17:22:31 david DAVID-LAPTOP PageOpen InstallCompleteDialog   2012/10/21:17:22:57 david DAVID-LAPTOP === Setup ended ===
2012/10/21:17:23:19 david DAVID-LAPTOP === Setup started on DAVID-LAPTOP by david === 2012/10/21:17:23:19 david DAVID-LAPTOP Launch 2012/10/21:17:23:22 david DAVID-LAPTOP === Setup ended ===
2012/10/21:17:23:59 david DAVID-LAPTOP === Setup started on DAVID-LAPTOP by david === 2012/10/21:17:23:59 david DAVID-LAPTOP Launch 2012/10/21:17:24:02 david DAVID-LAPTOP === Setup ended ===
2012/10/21:17:24:00 david DAVID-LAPTOP === Setup started on DAVID-LAPTOP by david === 2012/10/21:17:24:00 david DAVID-LAPTOP Launch 2012/10/21:17:24:02 david DAVID-LAPTOP PageOpen LaunchDialog   2012/10/21:17:24:06 david DAVID-LAPTOP PageOpen LicenseDialog   2012/10/21:17:24:11 david DAVID-LAPTOP PageOpen ProductInfoDialog   2012/10/21:17:25:39 david DAVID-LAPTOP PageOpen ProductSelectionDialog2   2012/10/21:17:25:54 david DAVID-LAPTOP PageOpen FullProgressDialog   2012/10/21:17:25:54 david DAVID-LAPTOP Installing DirectX® Runtime: C:\Autodesk\Autodesk_Revit_2013_English_Win_32bit-64bit\3rdParty\DirectX\DXSETUP.exe /silent 2012/10/21:17:26:47 david DAVID-LAPTOP Install DirectX® Runtime Succeeded  2012/10/21:17:26:47 david DAVID-LAPTOP Installing FaroSDK: C:\Autodesk\Autodesk_Revit_2013_English_Win_32bit-64bit\3rdParty\FaroSDK\e889_faro_ls_sdk_4.8.2.25521_x86_setup.exe /VERYSILENT /NORESTART /LOG="C:\Users\david\AppData\Local\Temp\FaroSDK.log" 2012/10/21:17:26:51 david DAVID-LAPTOP Install FaroSDK Succeeded  2012/10/21:17:26:51 david DAVID-LAPTOP Installing Autodesk® Revit® 2013:  TRANSFORMS="C:\Autodesk\Autodesk_Revit_2013_English_Win_32bit-64bit\x64\en-us\RVT2013\RVT2013.mst;C:\Users\david\AppData\Local\Temp\_AI9561.tmp\x64\RVT2013\RVT2013-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Revit_2013_English_Win_32bit-64bit\" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/21:17:26:51 david DAVID-LAPTOP Install Autodesk® Revit® 2013 Failed Installation aborted, Result=1618 2012/10/21:17:26:51 david DAVID-LAPTOP Rollback FaroSDK Failed Failure is ignored, Result=1618 2012/10/21:17:26:51 david DAVID-LAPTOP Rollback DirectX® Runtime Failed Failure is ignored, Result=1618
3 REPLIES 3
DannyHubbard
Are you actually getting an error during the install, or are you canceling the install? Stage 5 of the install is generally where the install is downloading content to be install. Depending on what content you choose to install and your internet speed this can take a long time to complete, in most cases people with this problem just let it run overnight.
http://upandready.typepad.com/up_and_ready/2012/07/revit-2013-will-hang-at-preparing-revit-content.h...
Danny
Danny Hubbard
QA Analyst
Autodesk, Inc.
TravisNave
in reply to: DannyHubbard
Danny is right.  Revit has a lot of data to download on step 5.  Run your installer and then go to bed. When you wake up, you'll have Revit installed.  Smiley Very Happy
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
in reply to: TravisNave
hello everybody
Just want to add wht worked errors out for me:
- Run a windows update (solved C++ installation hanging)
- Disable Firewall before installing
- Add *://*.autodesk.com to "trusted sites" under security options of the netwok properties.
All the above on Windows 7 Machine SP 1 with 4 Gigs RAM
The only problem now is....
I have NVIDIA Cards everywhere and some are not supported!!!
ciao,
Stefano
Administrator Productivity
