Installation & Licensing
New Member
dtsung
Message 1 of 4 (1,845 Views)
Can not install Revit 2013 on my new laptop
1845 Views, 3 Replies
10-21-2012 05:43 PM
I just bought a new Dell laptop with i-7. I tried to install Revit 2013 on it, always stoped at 5 of 8 remaining.
Here is the log file, please help!
2012/10/20:20:07:00 david DAVID-LAPTOP === Setup started on DAVID-LAPTOP by david === 2012/10/20:20:07:00 david DAVID-LAPTOP Launch 2012/10/20:20:07:00 david DAVID-LAPTOP CommandLine /url "http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/Autodesk_Revit_2013_English_Win_32_64bit_w..." /SN 900-32782528 /PK 829E1 /student /skipEULA /akamai /auth  /sid   2012/10/20:20:11:36 david DAVID-LAPTOP === Setup ended ===
2012/10/20:23:02:27 david DAVID-LAPTOP === Setup started on DAVID-LAPTOP by david === 2012/10/20:23:02:27 david DAVID-LAPTOP Launch 2012/10/20:23:02:27 david DAVID-LAPTOP CommandLine /url "http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/Autodesk_Revit_2013_English_Win_32_64bit_w..." /SN 900-32782528 /PK 829E1 /student /skipEULA /akamai /auth  /sid   2012/10/20:23:02:29 david DAVID-LAPTOP === Setup ended ===
2012/10/20:23:02:28 david DAVID-LAPTOP === Setup started on DAVID-LAPTOP by david === 2012/10/20:23:02:28 david DAVID-LAPTOP Launch 2012/10/20:23:02:28 david DAVID-LAPTOP Download Skipped SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/SET... 2012/10/20:23:02:29 david DAVID-LAPTOP PageOpen LaunchDialog   2012/10/20:23:03:51 david DAVID-LAPTOP PageOpen LicenseDialog   2012/10/20:23:03:51 david DAVID-LAPTOP PageOpen ProductInfoDialog   2012/10/20:23:03:51 david DAVID-LAPTOP PageOpen ProductSelectionDialog2   2012/10/20:23:04:03 david DAVID-LAPTOP PageOpen FullProgressDialog   2012/10/20:23:04:04 david DAVID-LAPTOP Download Skipped VCREDIST2005X86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/VCR... 2012/10/20:23:04:04 david DAVID-LAPTOP Installing Microsoft Visual C++ 2005 Redistributable (x86): C:\Autodesk\WI\Autodesk Revit 2013\3rdParty\x86\VCRedist\2005\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\david\AppData\Local\Temp\vcredist_x86_2005.log"" " 2012/10/20:23:04:05 david DAVID-LAPTOP Install Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1603 2012/10/20:23:04:07 david DAVID-LAPTOP PageOpen InstallCompleteDialog   2012/10/20:23:05:00 david DAVID-LAPTOP === Setup ended ===
2012/10/20:23:09:35 david DAVID-LAPTOP === Setup started on DAVID-LAPTOP by david === 2012/10/20:23:09:35 david DAVID-LAPTOP Launch 2012/10/20:23:09:35 david DAVID-LAPTOP CommandLine /url "http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/Autodesk_Revit_2013_English_Win_32_64bit_w..." /SN 900-32782528 /PK 829E1 /student /skipEULA /akamai /auth  /sid   2012/10/20:23:09:38 david DAVID-LAPTOP === Setup ended ===
2012/10/20:23:09:36 david DAVID-LAPTOP === Setup started on DAVID-LAPTOP by david === 2012/10/20:23:09:36 david DAVID-LAPTOP Launch 2012/10/20:23:09:37 david DAVID-LAPTOP Download Skipped SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/SET... 2012/10/20:23:09:38 david DAVID-LAPTOP PageOpen LaunchDialog   2012/10/20:23:10:49 david DAVID-LAPTOP PageOpen LicenseDialog   2012/10/20:23:10:49 david DAVID-LAPTOP PageOpen ProductInfoDialog   2012/10/20:23:10:49 david DAVID-LAPTOP PageOpen ProductSelectionDialog2   2012/10/20:23:11:07 david DAVID-LAPTOP PageOpen FullProgressDialog   2012/10/20:23:11:07 david DAVID-LAPTOP Download Skipped VCREDIST2005X86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/VCR... 2012/10/20:23:11:08 david DAVID-LAPTOP Installing Microsoft Visual C++ 2005 Redistributable (x86): C:\Autodesk\WI\Autodesk Revit 2013\3rdParty\x86\VCRedist\2005\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\david\AppData\Local\Temp\vcredist_x86_2005.log"" " 2012/10/20:23:11:09 david DAVID-LAPTOP Install Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1603 2012/10/20:23:11:10 david DAVID-LAPTOP PageOpen InstallCompleteDialog   2012/10/20:23:14:19 david DAVID-LAPTOP === Setup ended ===
2012/10/20:23:28:50 david DAVID-LAPTOP === Setup started on DAVID-LAPTOP by david === 2012/10/20:23:28:50 david DAVID-LAPTOP Launch 2012/10/20:23:28:50 david DAVID-LAPTOP CommandLine /url "http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/Autodesk_Revit_2013_English_Win_32_64bit_w..." /SN 900-32782528 /PK 829E1 /student /skipEULA /akamai /auth  /sid   2012/10/20:23:28:53 david DAVID-LAPTOP === Setup ended ===
2012/10/21:17:02:54 david DAVID-LAPTOP === Setup started on DAVID-LAPTOP by david === 2012/10/21:17:02:54 david DAVID-LAPTOP Launch 2012/10/21:17:02:59 david DAVID-LAPTOP === Setup ended ===
2012/10/21:17:21:33 david DAVID-LAPTOP === Setup started on DAVID-LAPTOP by david === 2012/10/21:17:21:33 david DAVID-LAPTOP Launch 2012/10/21:17:21:36 david DAVID-LAPTOP === Setup ended ===
2012/10/21:17:21:34 david DAVID-LAPTOP === Setup started on DAVID-LAPTOP by david === 2012/10/21:17:21:34 david DAVID-LAPTOP Launch 2012/10/21:17:21:36 david DAVID-LAPTOP PageOpen LaunchDialog   2012/10/21:17:21:45 david DAVID-LAPTOP PageOpen LicenseDialog   2012/10/21:17:21:49 david DAVID-LAPTOP PageOpen ProductSelectionDialog2   2012/10/21:17:21:59 david DAVID-LAPTOP PageOpen FullProgressDialog   2012/10/21:17:22:00 david DAVID-LAPTOP Installing Network License Manager:  ALLUSERS=1 INSTALLDIR="C:\Program Files\Autodesk\Autodesk Network License Manager\"  ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Revit_2013_English_Win_32bit-64bit\" INSTALLDIR="C:\Program Files\Autodesk Network License Manager\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/21:17:22:00 david DAVID-LAPTOP Install Network License Manager Failed Failure is ignored, Result=1618 2012/10/21:17:22:00 david DAVID-LAPTOP Installing Autodesk CAD Manager Tools:   INSTALLDIR="C:\Program Files\Autodesk\Autodesk CAD Manager Tools\"  ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Revit_2013_English_Win_32bit-64bit\" INSTALLDIR="C:\Program Files\Autodesk\CAD Manager Tools\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/21:17:22:00 david DAVID-LAPTOP Install Autodesk CAD Manager Tools Failed Failure is ignored, Result=1618 2012/10/21:17:22:00 david DAVID-LAPTOP Installing Revit Software Development Kit: C:\Autodesk\Autodesk_Revit_2013_English_Win_32bit-64bit\Utilities\SDK\RevitSDK.exe -d"C:\Revit SDK 2013" 2012/10/21:17:22:31 david DAVID-LAPTOP Install Revit Software Development Kit Succeeded  2012/10/21:17:22:31 david DAVID-LAPTOP PageOpen InstallCompleteDialog   2012/10/21:17:22:57 david DAVID-LAPTOP === Setup ended ===
2012/10/21:17:23:19 david DAVID-LAPTOP === Setup started on DAVID-LAPTOP by david === 2012/10/21:17:23:19 david DAVID-LAPTOP Launch 2012/10/21:17:23:22 david DAVID-LAPTOP === Setup ended ===
2012/10/21:17:23:59 david DAVID-LAPTOP === Setup started on DAVID-LAPTOP by david === 2012/10/21:17:23:59 david DAVID-LAPTOP Launch 2012/10/21:17:24:02 david DAVID-LAPTOP === Setup ended ===
2012/10/21:17:24:00 david DAVID-LAPTOP === Setup started on DAVID-LAPTOP by david === 2012/10/21:17:24:00 david DAVID-LAPTOP Launch 2012/10/21:17:24:02 david DAVID-LAPTOP PageOpen LaunchDialog   2012/10/21:17:24:06 david DAVID-LAPTOP PageOpen LicenseDialog   2012/10/21:17:24:11 david DAVID-LAPTOP PageOpen ProductInfoDialog   2012/10/21:17:25:39 david DAVID-LAPTOP PageOpen ProductSelectionDialog2   2012/10/21:17:25:54 david DAVID-LAPTOP PageOpen FullProgressDialog   2012/10/21:17:25:54 david DAVID-LAPTOP Installing DirectX® Runtime: C:\Autodesk\Autodesk_Revit_2013_English_Win_32bit-64bit\3rdParty\DirectX\DXSETUP.exe /silent 2012/10/21:17:26:47 david DAVID-LAPTOP Install DirectX® Runtime Succeeded  2012/10/21:17:26:47 david DAVID-LAPTOP Installing FaroSDK: C:\Autodesk\Autodesk_Revit_2013_English_Win_32bit-64bit\3rdParty\FaroSDK\e889_faro_ls_sdk_4.8.2.25521_x86_setup.exe /VERYSILENT /NORESTART /LOG="C:\Users\david\AppData\Local\Temp\FaroSDK.log" 2012/10/21:17:26:51 david DAVID-LAPTOP Install FaroSDK Succeeded  2012/10/21:17:26:51 david DAVID-LAPTOP Installing Autodesk® Revit® 2013:  TRANSFORMS="C:\Autodesk\Autodesk_Revit_2013_English_Win_32bit-64bit\x64\en-us\RVT2013\RVT2013.mst;C:\Users\david\AppData\Local\Temp\_AI9561.tmp\x64\RVT2013\RVT2013-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Revit_2013_English_Win_32bit-64bit\" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/21:17:26:51 david DAVID-LAPTOP Install Autodesk® Revit® 2013 Failed Installation aborted, Result=1618 2012/10/21:17:26:51 david DAVID-LAPTOP Rollback FaroSDK Failed Failure is ignored, Result=1618 2012/10/21:17:26:51 david DAVID-LAPTOP Rollback DirectX® Runtime Failed Failure is ignored, Result=1618
Employee
DannyHubbard
Message 2 of 4 (1,826 Views)
Re: Can not install Revit 2013 on my new laptop
10-22-2012 05:20 AM in reply to: dtsung
Are you actually getting an error during the install, or are you canceling the install? Stage 5 of the install is generally where the install is downloading content to be install. Depending on what content you choose to install and your internet speed this can take a long time to complete, in most cases people with this problem just let it run overnight.
http://upandready.typepad.com/up_and_ready/2012/07/revit-2013-will-hang-at-preparing-revit-content.h...
Danny
Danny Hubbard
QA Analyst
TravisNave
Message 3 of 4 (1,816 Views)
10-22-2012 09:10 AM in reply to: DannyHubbard
Danny is right.  Revit has a lot of data to download on step 5.  Run your installer and then go to bed. When you wake up, you'll have Revit installed.  :smileyvery-happy:
Active Member
tecnicheparametriche
Message 4 of 4 (1,363 Views)
02-04-2013 08:34 AM in reply to: TravisNave
hello everybody
Just want to add wht worked errors out for me:
- Run a windows update (solved C++ installation hanging)
- Disable Firewall before installing
- Add *://*.autodesk.com to "trusted sites" under security options of the netwok properties.
All the above on Windows 7 Machine SP 1 with 4 Gigs RAM
The only problem now is....
I have NVIDIA Cards everywhere and some are not supported!!!
ciao,
Stefano
