I have just dowloaded the student version of autocad and when I go to activate the license it tells me my serial number is invalid. I uninstalled the whole program re-installed it and I was given the same serial number and it still says that the serial number is invalid.
Hello @livetodie_23 Welcome to the Community!
There are a few things that could be causing this error, however the most common is a registration issue. I attempted to find your account under your community registered email address and was not able to find any associated serial numbers. The best point of contact would be with our Activation and Registration Team. They can be contacted via a live chat by:
1. Visiting http://knowledge.autodesk.com/contactus
2. Select “Activation & Registration” or “License Management”
3. Select appropriate subtopics from the pull-down menus
4. Select “I Still Need Help” if you need personal assistance
Be sure to have your product, version, serial number and request code if possible.
Please let us know you if you have any additional questions!
