My Operations System is Windows Vista 32.-bit. I was able to install 2013 version but what we use in class is Maya 2014. An attempt to install 2014 gave me an alert that I am trying to install a 64-bit software on a 32-bit OS. Is there any other way around this other than upgrading my system? Thanks.
Solved by david.lau. Go to Solution.
Maya 2014 is 64 bit ONLY. There is no workaround for this problem. Also, Vista is not supported in any 2014 product.
http://upandready.typepad.com/up_and_ready/2012/01/general-systems-windows-vista-rip.html
system requirements: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=15458252&linkID=9242258&CMP=OTC-RSS...
DarrenP
Please help me from where can i install the maya 32 bit
this version is not available anymore from autodesk
DarrenP
