Installation & Licensing
Can I generate Activation request code manually?
7 REPLIES 7
Message 1 of 8
el.mustafa
2485 Views, 7 Replies
Hi everyone,
I've installed Maya2011 on Red Hat Enterprise Linux 6.
The install does not report any errors but for some bizarre reason
Maya is refusing to generate a request code so that I can send
to the Authorization centre and activate the product.
Is there a way to generate a code using the shell instead?
Thanks in advance
EL
7 REPLIES 7
Message 2 of 8
el.mustafa
in reply to: el.mustafa
As an update I tried reinstalling but this time using the command line to register for a license.
I get a "serial number not recongnised, Call set SerialNumber"
That is puzzling as I've used the number to activate many times before. In fact Maya2011 is running fine on the same computer under Mac OS X on a secondary hard drive. But of course the Linux version always has to misbehave as you'd expect !
Gratitude in advance.
El
Message 3 of 8
hashim.mundol
Sorry to hear about the activation issues.
Please delete this file and try again,(if exists)
/var/opt/Autodesk/Adlm/.config/ProductInformation.pit
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
For more tips & tricks: http://upandready.typepad.com
Hashim Mundol
Autodesk Product Support
Autodesk, Inc.
Message 4 of 8
el.mustafa
in reply to: hashim.mundol
Many many thanks
In fact whilst waiting for a reply I dug out my student serial number and it worked!
Not sure why my commercial license serial was causing such errors
Take good care of yoursel
El
Message 5 of 8
Darin.Green
Wouldn't that delete all of the existing activations as well?
If this information was helpful, please consider using the Accept Solution
Message 6 of 8
hashim.mundol
in reply to: Darin.Green
Yes it is for all the Autodesk products (2010/2011)
This will not delete activation itself. if you reinstall with the same product key and serial number the re-activation might not be necessary
Hashim Mundol
Autodesk, Inc.
Message 7 of 8
Darin.Green
Alright... I guess I'll have to reinstall.
Message 8 of 8
hashim.mundol
Yes, thats the only method to recreate this file.. 😞
Hashim Mundol
Autodesk, Inc.
Administrator Productivity
