Installation & Licensing
can Building Design Suite Standrad install in 32 bits machine
1 REPLY 1
pritcad
181 Views, 1 Reply
Autodesk Building Design Suite standard is only available for 64 bits in USB media. how to install if I have 32 bits machine?
pritam
1 REPLY 1
JoAnn_Hogan
in reply to: pritcad
You can either download a trial version from Autodesk.com and activate it using your serial number and product key. Or you can request a 32-bit USB from Autodesk or your VAR (Value Added Reseller).
I am not sure why the USB's are only 64-bit. But they said if you need 32-bit you have to request 32-bit. Mainly the reason why you need to download your upgrades now.
If this post solved your issue please mark as solved and Kudos are always welcome 😃
Jo - Ann
Twitter: @JoAnn_Hogan
Revit Architecture Certified Professional / Revit Structure Certified Professional / AutoCAD Certified Professional
Administrator Productivity
