Installation & Licensing
Active Contributor
pritcad
Message 1 of 2 (74 Views)
can Building Design Suite Standrad install in 32 bits machine
74 Views, 1 Replies
03-02-2014 10:24 PM
Autodesk Building Design Suite standard is only available for 64 bits in USB media. how to install if I have 32 bits machine?
pritam
JoAnn_Hogan
Message 2 of 2 (65 Views)
Re: can Building Design Suite Standrad install in 32 bits machine
03-02-2014 11:20 PM in reply to: pritcad
You can either download a trial version from Autodesk.com and activate it using your serial number and product key. Or you can request a 32-bit USB from Autodesk or your VAR (Value Added Reseller).
I am not sure why the USB's are only 64-bit. But they said if you need 32-bit you have to request 32-bit. Mainly the reason why you need to download your upgrades now.
If this post solved your issue please mark as solved and Kudos are always welcome =)
Jo - Ann (P.S follow me on twitter @JoAnn_Hogan)
AutoCAD Certified Professional 2014 / Inventor Certified Professional 2014
