Thank you all.
After many phone calls, it turns out that the issue was the serial number.
LAthough my reseller knew what I was planning to do, something got crossed
up along the way, and the serial number that was shipped was for a stand
alone seat.
The guy at Adesk gave a somewhat confusing representation of the issue. The
problem is not that Overlay won't do what I want, the problem is that Adesks
authorization program will not issue the codes for what I want to do based
on that serial number.
Conveniently, all I need is a new serial number and CD key, and all will be
well. I can actiually use the same media.
"Petri Ahava"
wrote in message
news:355A1CDAF4CA0F2754AC7748E53E413C@in.WebX.maYIadrTaRb...
> Hi,
> the CAD Overlay CD has a netsetup folder. The setup there builds the
> deployment. There is no license manager installation, which is easy to
> understand as COVL will only work with AutoCAD anyway! If it's CAD Overlay
> 2000 or 2000i, use the Elan AdLM and ask for an authorization code using
the
> servercode found in the AutoCAD's running AdLM-service. You can add the
COVL
> authorization to the same server that deals out AutoCAD licenses. If you
> have AutoCAD 2002 and COVL 2002, ask for a license file for CAD Overlay
> using the same hostname and ethernet address you used for AutoCAD. Then
> append the new information to the license file like this:
> SERVER server1 00aa22bb33cc
> USE_SERVER
> VENDOR adskflex port=2080
> INCREMENT 41100ACD_2002_0F adskflex 1.000 permanent 2 \
> VENDOR_STRING=nfr:permanent SUPERSEDE DUP_GROUP=H \
> ISSUED=30-jul-2001 ck=199 SN=700-12345678 SIGN=1234CC34VV
> INCREMENT 40700CADOV_2002_0F adskflex 1.000 permanent 2 \
> ISSUED=30-jul-2001 ck=170 SN=700-87654322 SIGN=C45SE123DR6Y
> You have to install the CAD Overlay in both cases using the deployment,
> otherwise CAD Overlay won't know to look for the NW license!
> HTH
> Petri Ahava
> CAD-Quality Finland Oy
> "Charles Prettyman" wrote in message
> news:D7A8A8F60911FCE222E946A55FDBF8FE@in.WebX.maYIadrTaRb...
> > I had a discussion with my reseller about CAD overlay in which I was
> > informed that I could add one license of COV as a feature in my license
> > file, so that one person, out of the 8 of us could be using it, along
with
> > the 8 ADT licenses. That seemed to suit our needs, so we purchased that
> one
> > license, and now AutoDesk is saying that that is not an option.
> > Has anyone had experience with COV as a feature in ADLM? Who is giving
me
> > bad information, my reseller, or the poor schmuck that AutoDesk stuck
at
> > phone for authorization codes?
