When users login to the TS server which is Windows 2003 32 bit and try to open AutoCAD 2014 as a user it goes through a setup for about 2-3 sec and disappears and won’t open
Users are limited user accounts and under Administrator account it works fine
User accounts have folder redirection
if i login as the user local on the server after a setup process i get this error
any help would be great
Isn't that the answer? Your user accounts are restricted to much.
The other problem I see is: what has the user (none admin) to search in the users-folder from the administrator (in screenshot)?
What you can try is to reset the profile for that user (from the Windows start menu) so that this user can start AutoCAD from scratch.
- alfred -
Yes and no
Yes I know it’s from restricted account however it works on the workstations with the same accounts and we can raise user rights
Does anyone know what read/wright access they need in the drive and registry?
Extra info
On server 2008 r2 the AutoCAD opens but has a onetime font registry issue
I will have to reread the 2014 EULA, but I am pretty certain this violates the license agreement. DarrenP, any comments?
Autocad wasn't made to run on a server OS and yes this violates the EULA
you need to look at citrix to be complaint with the EULA
DarrenP
