Installation & Licensing
Darin.Green
Message 11 of 19 (130 Views)
Re: C3D won't start
10-19-2011 01:08 PM in reply to: caddman6425nah
Since you're an Admin on the machine, there's nothing that needs to be done in the registry.
Originally, I was going to have you right-click each of the registry hives and choose Permissions. Within the permissions area, add your account and allocate full rights.
However, since you already have Admin rights, there could be an AutoCAD profile issue. To reset your profile, perform the following:
Browse the registry and delete the following folder:
  • HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R18.2\ACAD-A000:409\
Browse windows explorer and delete the following:
  • C:\Users\<<Username>>\AppData\Local\Autodesk\C3D 2012
  • C:\Users\<<Username>>\AppData\Roaming\Autodesk\C3D 2012
Once these folders are deleted, start Civil 3D 2012 and those files (Autodesk Profile) will be recreated.
Let me know if this works.
Darin Green
Synergis Technologies
If this resolve your issue/question, give Kudos or Accept as Solution...
Distinguished Contributor
caddman6425nah
Message 12 of 19 (129 Views)
Re: C3D won't start
10-19-2011 01:13 PM in reply to: Darin.Green
You do remember I have a bunch of Adesk products running just fine, is this going to screw up any or all of the other applicatiions or reset the registration so I have to reregister them all again?
Nick
AEC Design Services
Darin.Green
Message 13 of 19 (127 Views)
Re: C3D won't start
10-19-2011 01:14 PM in reply to: caddman6425nah
No, this will only effect Civil 3D 2012. :smileyhappy:
Darin Green
caddman6425nah
Message 14 of 19 (115 Views)
Re: C3D won't start
10-20-2011 11:56 AM in reply to: Darin.Green
I thought that I got back with you, I guess I didn't. OK, it didn't work, still the same.
Nick
AEC Design Services
caddman6425nah
Message 15 of 19 (100 Views)
Re: C3D won't start
10-29-2011 10:44 AM in reply to: caddman6425nah
Tried everything, did a reinstall and still happens, but noticed that it flashs and crashes at the point when it says that its doing the CUI load. Then blink, flash the workspace, then nothing. Anyone???
Nick
AEC Design Services
caddman6425nah
Message 16 of 19 (88 Views)
Re: C3D won't start
11-08-2011 10:37 AM in reply to: caddman6425nah
HELLLLLOOOOOO!!!!!! And people wonder why I act annoyed??
Nick
AEC Design Services
Darin.Green
Message 17 of 19 (78 Views)
Re: C3D won't start
11-10-2011 07:28 AM in reply to: caddman6425nah
caddman,
If you're running Windows 7, disable the UAC...
Go to the start menu, and type UAC in the search box then hit Enter. Slide the bar all the way to the bottom and reboot your system.
If this doesn't resolve the issue, browse to the following location and delete all of the files beginning with "adskflex_":
Windows 7 directory:
  • C:\ProgramData\FLEXnet\
Windows XP directory:
  • C:\Documents and Settings\All Users\Application Data\
Darin Green
caddman6425nah
Message 18 of 19 (75 Views)
Re: C3D won't start
11-10-2011 08:54 AM in reply to: Darin.Green
UAC was turned off, deleted all adskflex_ file, there were 2 files and one log file. Now it works, thanks! :-)
Nick
AEC Design Services
Darin.Green
Message 19 of 19 (72 Views)
Re: C3D won't start
11-10-2011 09:02 AM in reply to: caddman6425nah
You're welcome!
Darin Green
