Installation & Licensing
205 Kudos
Post 11 of 18
Re: Need Help on Install!!! (yes, I saw the sticky)
05-09-2013 03:18 PM in reply to: Postmaster_G
Postmaster_G wrote:
From the desktop... I have my license server setup properly as it works for 2012.
... perhaps I will get a better response when I submit my error log).
Are you trying to install a network version of 2013 or a standalone version?
Murph
Supportting the troops daily.
Valued Contributor
3 Kudos
Post 12 of 18
05-10-2013 08:07 PM in reply to: Murph
It is a network version, the same as my 2012.  They are on the same server and the 2012 finds the files just fine.
I am getting ready right now to install 2013 once again so I can generate the error log and post it here.
Valued Contributor
3 Kudos
Post 13 of 18
05-10-2013 09:00 PM in reply to: Postmaster_G
Well,  Here is what the install log gave me...
Valued Contributor
3 Kudos
Post 14 of 18
05-10-2013 09:04 PM in reply to: Postmaster_G
I ran the install again, and this is what it now says.  I has done this before so I wont be supprised if it doesn't start again.
I am rebooting now.
Distinguished Mentor
37 Kudos
Post 15 of 18
05-13-2013 03:56 AM in reply to: Postmaster_G
If you copied a server deployment to a thumb drive that will not work, there are initialization files pointing to resources & license information in the deployment that point back to the server. The only way this would work is if you had a connection to your work network from home like a Virtual Private Network (VPN) connection.
Mike Robertson
FL. Dept. of Transportation
CADD Applications Developer
Valued Contributor
3 Kudos
Post 16 of 18
05-15-2013 12:27 PM in reply to: michael.robertson
Actually, it has worked before.  That is how I got C3D 2013 installed on my old pc.  The same package actually!?!
Valued Contributor
3 Kudos
Post 17 of 18
05-20-2013 12:35 PM in reply to: Postmaster_G
... I hope I am not going to have to install xP just to run civil 3D!
:catsad:
Valued Contributor
3 Kudos
Post 18 of 18
06-01-2013 02:09 PM in reply to: michael.robertson
...oh sorry, didn't mention that I am connecting over VPN and I have setup the proper environmental variables to connect to my license server (thus the reason I am able to startup my network version of 2012 - and previously 2013).  As I think I mentioned before, I had installed the same package on my old computer and everything ran fine, from home over vpn.
