Installation & Licensing
Building Design Suite Premium
3 REPLIES 3
479 Views, 3 Replies
The installation of the suite fails while in the process of installing Faro L.S
it reboots the system.
Before starting the installation I cleaned out all temp. folders and disabled the anti virus.
3 REPLIES 3
TravisNave
There's a handful of different fixes for this.  Might do a quick search to see which one works for you.
http://forums.autodesk.com/t5/Installation-Licensing/Error-on-install-of-AutoCAD-Mechanical-2012/td-...
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
in reply to: TravisNave
Thanks for the suggestions.
As it is i had it looked at by my IT expert.
The problem was  related to an exernal WD harddrive that interfered with the installation
once that software was removed all was well.
TravisNave
Good to know.  That will be one more thing for the next person to try when they have this error.  Thanks for sharing your solution.
Autodesk Forums:
Administrator Productivity
