The installation of the suite fails while in the process of installing Faro L.S
it reboots the system.
Before starting the installation I cleaned out all temp. folders and disabled the anti virus.
Solved by HansWiemers8861. Go to Solution.
There's a handful of different fixes for this. Might do a quick search to see which one works for you.
Thanks for the suggestions.
As it is i had it looked at by my IT expert.
The problem was related to an exernal WD harddrive that interfered with the installation
once that software was removed all was well.
Good to know. That will be one more thing for the next person to try when they have this error. Thanks for sharing your solution.
