Hi all,
We used local account (have local administrator rights) to install BDSPRM 2013 in Windows XP 32 Bit and find that there is any errors during the installation. I have no idea to solve the installation problem.
Hardware all are meet the system requirement
Installed products during the installation:
- AutoCAD 2013
- Revit 2013
- 3ds Max Design 2013
- Navisworks Simulate 2013
4 of 30 pcs that cannot install successful. (All 4 products)
2 pcs have error message in Navisworks Simulate 2013 installation (Attachment: installation errors.zip)
* i have a full rights on D partition
2 pcs will automatically reboot when i install Revit 2013 product. (Attachment: Revit2013.zip)
* no error message pop-up and reboot pc, installation failed
* Also, i tried to install single Revit 2013 product, it reboots again, installation failed
Is there any solution?
Thank you for your help!
Welcome to the community. Sounds like you have almost completed your entire Autodesk product roll out to all your PC’s. I find it strange that you were only seeing problems with only 4 pc. What’s different about these 4 PC’s? I do not normally suggest this but a quicker solution might be to format and install a new image on the 4 pc. If you have time to troubleshoot you can try the following:
Thank you for using the community.
We cannot install software on C partition base on company policy. All machines are same settings, but i have no idea why i cannot install Revit / Navisworks on some machines.
But, why the pc reboot automatically during Revit 2013 installation?
I will try your suggestions.
Hayes
I think this maybe the issue.
Hi David
i knew that issue before, so we do not include any update in BDS 2013 / 2014 installation.
Any idea why the machine will automatically reboot during Revit installation without any pop-up message?
Hayes
Another suggestion from me is please update your system first to install all the important updates, and then try to reinstall, see if works.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Hello. A few years back most major programs would ask for a reboot. This was usually tied to the program requirements based on eth languages that they were programmed in. So, earlier versions of NET often seemed to require programs to restart. There was also earlier versions of the MS Installer as it was installed on different operating systems. Older versions used to require a reboot, the more updated versions generally do not.
Our later versions, assuming the target machines have an updated MS installer and NET, I would not expect them to force a reboot. This is assuming you are using the regular installation procedures and are not trying to modify the setup.ini files or install via custom command. They can complicate the installation process and odd behaviors like this can spawn.
Thank you for taking part in our community!
