Hello.
I build a deployment on one server which is a license server and then install this deployment on a windows client. I'd like clone this windows client and install it on another machine, but this machine use another server which is a license server too (another mac and another name) .
When i run inventor on this last machine it doesn't find license server. I write the name of new server but it doesn't works.
It's possible ?
Thanks.
Solved by emily.xu. Go to Solution.
This is because your client unable to find your license server, you can try the follwing steps to see if you can launch your program:
1 set environment variable : ADSKFLEX_LICENSE_FILE, and the value is : @servername (servername is your second server name)
2 find Licpath.lic file in your installation fold,open it with notepad, modify the context same to the first two lines of your license file:
for example: SERVER servername 000000000000
USE_SERVER
note: here the servername is your second server name, and replace 000000000000 by your server MAC address.
3 check your register,HKEY_LOCAL_MACHINE\SOFTWARE\FLEXlm License Manager\ADSKFLEX_LICENSE_FILE, and the value is @@servername
Hope this helps.
I have used the second option and it works, but is not necesary change the mac address in licpath.lic. Using 00000000 works fine.
Thanks.
