Installation & Licensing
Active Contributor
2 Kudos
Post 1 of 4
Buidling Design Suite Ultimate 2014 - Installation Error
358 Views, 3 Replies
04-24-2013 09:14 AM
When running installation of the Design Suite Ultimate 2014 I am getting the following error:
Error applying transforms. Verify that the specified transform paths are valid.
And the path is valid.
*Expert Elite*
902 Kudos
Post 2 of 4
Re: Buidling Design Suite Ultimate 2014 - Installation Error
04-25-2013 08:40 AM in reply to: twilks1
Are you installing from media or download?
Active Contributor
2 Kudos
Post 3 of 4
04-25-2013 11:04 AM in reply to: twilks1
Download
*Expert Elite*
902 Kudos
Post 4 of 4
04-25-2013 12:11 PM in reply to: twilks1
Start here:
http://support.microsoft.com/mats/Program_Install_and_Uninstall/
You might also try this:
In regedit, go to the following key:
HKEY_LOCAL_MACHINE\Software\Classes\Installer\Products\<Product>\
'Product' is the ID of the Autodesk program (good luck) and check if there's a 'transform' entry on the
registry key you believe to be created by the installer. Check if this entry is
pointing to a valid Windows installation drive (i.e. C:\), and if not, change it.
Post to the Community
New Post
Announcements
Are you interested in helping shape the future of the Autodesk Community? To participate in this brief usability study, please click here. Your time and input is greatly appreciated!
