Installation & Licensing
Buidling Design Suite Ultimate 2014 - Installation Error
3 REPLIES 3
559 Views, 3 Replies
When running installation of the Design Suite Ultimate 2014 I am getting the following error:
Error applying transforms. Verify that the specified transform paths are valid.
And the path is valid.
Tags (1)
3 REPLIES 3
TravisNave
Are you installing from media or download?
Autodesk Forums:
Download
TravisNave
Start here:
http://support.microsoft.com/mats/Program_Install_and_Uninstall/
You might also try this:
In regedit, go to the following key:
HKEY_LOCAL_MACHINE\Software\Classes\Installer\Products\<Product>\
'Product' is the ID of the Autodesk program (good luck) and check if there's a 'transform' entry on the
registry key you believe to be created by the installer. Check if this entry is
pointing to a valid Windows installation drive (i.e. C:\), and if not, change it.
Autodesk Forums:
Administrator Productivity
