Installation & Licensing
Bridge modeler 2013 installation error
4 REPLIES 4
709 Views, 4 Replies
I am trying to install bridge modeler plugin for C3D 2013. I always end up in a fatal error (image attached). Can anyone tell whats the issue?
Thanks!
4 REPLIES 4
jessica.t
Hi Bharathwaj!
This appears to be a Microsoft error that can be repaired using one of their "fixit" links. Please "Accept as a Solution" if this post resolves your issue so that others with this same question can more easily find an answer, if not please respond to this post with further information. Thank you!
Jessica Thrasher
in reply to: jessica.t
Hi Jessica,
Thank you so much for the help!. It did help me understand that it is actually a Microsoft issue. However, it didn't fix my problem as the tool couldn't identify the 2343 error in my computer by default, nor it showed the "bridge modeler 2013 " in the list of software available for fixing using manual selection.
PS: I didn't face this issue at all with C3D 2012 + Bridge modeler 2012.
jessica.t
Thanks for the clarification! But I do see that your case has been escalated to our technical support team, if there's any chance you could share the answer with the community by posting it here upon resolution it would be a great service. Thank you!
Jessica Thrasher
Hey,
The problem had been resolved. I repaired the C3D 2013 program from Control panel and this helped me successfully install the bridge modeler plugin.
Thank you for helping in!..
Administrator Productivity
