When starting BREPLACE I receive the below notification, the command cannot be executed.
Entitlement is not available or enabled.
I'm using a single user license and I have all services assigned.
Is someone else experiencng the same issue?
Note: I was looking into this and found that the command sends a server request to developer.api.autodesk.com, using a server in Europe (57.74.47.69). The Response code was 200 (OK), but there is an SSL-error; the certification seems to have been expired.
perhaps contact Autodesk directly or if you purchased through a reseller contact them?
I have the same issue, you can get around it using the BLOCKREPLACE command.
Now I'm concerned other basic commands will be broken...
Unfortunately BLOCKREPLACE only works if you have Express Tools.
Also it's not as graphically friendly as the new BREPLACE command.
