Installation & Licensing
Member
david.durston
Message 1 of 23 (2,279 Views)
Blue screen error when launching Autodesk products
2279 Views, 22 Replies
07-26-2012 01:54 AM
Hello, hoping posting here will help me fix a problem or at least become more aware of the problem.
I've been using Max and Maya for a while now (over a year) and suddenly yesterday morning, they both began to give me BSODs when launching.  I hadn't installed or changed anything on my comp between the last time it worked and it not working.
After trying to reinstall the programs, I also tried re-seating my graphics card and memory, I've updated to the most recent nvidia beta drivers and also tried rolling back to older ones. After none of that worked, today I decided to format and reinstall windows, also to no avail. I've run a hard drive check and memory diagnostic tool through windows, neither reporting errors. I downloaded and installed SoftImage and Blender to test and see if it was only Autodesk products or a 3D issue. SoftImage also blue-screens, but Blender and 3d apps/games still work fine. Since it's strictly Autodesk products, I'm posting on these forums hoping to find some more information and maybe even a fix.
Here is a picture of the exact BSOD error:
http://img.photobucket.com/albums/v255/JumpDog/IMAG0423.jpg?t=1343283516
Thanks for any help or ideas
DarrenP
Message 2 of 23 (2,273 Views)
Re: Blue screen error when launching Autodesk products
07-26-2012 06:02 AM in reply to: david.durston
TravisNave
Message 3 of 23 (2,266 Views)
07-26-2012 07:32 AM in reply to: david.durston
Darren is right, a 0x50 error tells me immediately that your hardware is toast.  Time to get a screwdriver.
Travis Nave Send TravisNave a Private Message                       Need help in your post? Mention me with @TravisNave
Member
david.durston
Message 4 of 23 (2,261 Views)
07-26-2012 10:50 AM in reply to: david.durston
Well, I'm quite aware of how to Google and had seen those pages already, but thanks for confirming that I guess. Just found it awkward that only Autodesk products seem to be affected by this and otherwise the computer is still behaving normally with all my other DCC tools and games/programs. Still not sure why it's singling out Autodesk and was sort of hoping to understand it a bit more on the technical side (like a faulty address in memory that only Autodesk seems to use or what?).
TravisNave
Message 5 of 23 (2,258 Views)
07-26-2012 11:01 AM in reply to: david.durston
Autodesk programs are more graphic and memory intensive than other applications.  That's why a faulty video driver will crash Inventor, but Call of Duty will continue to run fine.  :smileyvery-happy:
New Member
gonzo13290
Message 6 of 23 (2,234 Views)
07-30-2012 12:36 PM in reply to: david.durston
I started having the same problem (with 3ds max and Maya) at the same time.  All of my other programs work, including lightwave 10 (which i would imagine to be just as demanding of the computer as the Autodesk programs).  Everything worked fine before
TravisNave
Message 7 of 23 (2,228 Views)
07-30-2012 01:35 PM in reply to: gonzo13290
Check your driver version and BSOD stop error code.  And create a new thread if you're having problems.
Active Member
jyoung
Message 8 of 23 (2,178 Views)
08-03-2012 12:16 PM in reply to: david.durston
The draftsman in our office experienced this on a similiar date. He could run adobe CS6 products but autocad LT would crash BSOD on launch every time. We did a clean install and the exact same thing happened wth only autocad lt installed. Dell is telling us it is a software issue and not being helpful in fixing this issue.
DarrenP
Message 9 of 23 (2,176 Views)
08-03-2012 12:18 PM in reply to: jyoung
did you look up the blue screen error code?
Active Member
jyoung
Message 10 of 23 (2,175 Views)
08-03-2012 12:20 PM in reply to: jyoung
0x50
