Installation & Licensing
New Member
jakobuswagener
Message 61 of 209 (3,125 Views)
Re: Blank Activation Screen
11-03-2011 11:41 AM in reply to: aalza3eem
I have the same problem like aalza3eem.
can somebody help me?
Jakobus
New Member
mtwigg71
Message 62 of 209 (2,969 Views)
12-01-2011 08:03 AM in reply to: JohannC
This worked perfectly for me on AutoCAD 2012 Student Version, but I didn't have a folder call "L" I had one called"O" or a small square. Hope this helps.
Cheers.
Mickey
Member
basheeralan
Message 63 of 209 (2,955 Views)
12-04-2011 09:01 AM in reply to: JohannC
there is no folder named (internet setting) but thanks any way
New Member
jakobuswagener
Message 64 of 209 (2,945 Views)
12-04-2011 01:01 PM in reply to: gmijares
also ich habe das thema ja erstellt und konnte mir selbst mit diesem Link helfen
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=6404339&linkID=9240617
unten steht was von:
Editing files in the Webdepot Folder [i]
Another solution has been to edit the RTBeginReg.html file in the C:\Program Files\Common Files\Autodesk Shared\AdLM\R1\en-US\Webdepot folder. This is where the registry HTMLs are stored and these are the pages that the blank screen shows on.
Open the RTBeginReg.html in a text editor such as Notepad and add the following line of code below the <html> line:
<!-- saved from url=(0016)http://localhost -->
ja der blank activation screen war weg. dann noch schnell aktivieren. Dann hat man autodesk 3ds max 2012
ich find das echt gut von Autodesk. wenn man sich dann ein 3d programm irgentwann kaufen würde wäre das 3ds max, weil man sich schon gut eingearbeitet hat.
JarretDD
Message 65 of 209 (2,923 Views)
12-06-2011 08:30 AM in reply to: jakobuswagener
The above post, translated, is thanking the html tag solution for working, and prasing autodesk software.
Member
basheeralan
Message 66 of 209 (2,908 Views)
12-06-2011 12:04 PM in reply to: jakobuswagener
i also tried this way but that does not worked with me , in fact i tried all the ways above but none worked with me, please if you have another way tell me i became ahopless man, if any way does not work with me i will reinstall my win 7 agane
arlinpega.bibat
Message 67 of 209 (2,897 Views)
12-06-2011 06:56 PM in reply to: basheeralan
Hi:
You may send me your serial number through private message (envelope next to your account name at the top of this page) so I may check further and assist you with activation. Alternatively, please call our Registration and Activation Team Monday through Friday between 8 AM and 8 PM Eastern time at 800-551-1490.
Thanks!
Arlin Bibat
New Member
OsamaPro
Message 68 of 209 (2,819 Views)
12-25-2011 07:15 AM in reply to: gmijares
Hello
I have the same problem ... Problem can be resolved in the following way:
- Create another account on the computer ...
- Create the account Administrative ...
- Activate the program from the new account
- After activating the program, delete the new account
- Enjoy
Member
basheeralan
Message 69 of 209 (2,813 Views)
12-25-2011 11:48 AM in reply to: OsamaPro
thanx their
i tried the way which you told me but that did not work with me
arlinpega.bibat
Message 70 of 209 (2,807 Views)
12-25-2011 07:23 PM in reply to: basheeralan
Hi:
If you are from the United States, you may call our Registration and Activation Team Monday through Friday between 8 AM and 8 PM Eastern time at 800-551-1490 or email them at Authcodes@autodesk.com. If you are from Europe, you may contact them through  emea.register@activation.autodesk.com.
Thank you and have a nice day!
Arlin Bibat
