Installation & Licensing
JarretDD
Message 41 of 200 (5,432 Views)
Re: Blank Activation Screen
05-13-2011 06:15 PM in reply to: avto
Thanks for listing all those solutions. Took you guys a while, but It is sure to help a lot of people.
New Member
hausiusi
Message 42 of 200 (5,416 Views)
05-15-2011 11:54 AM in reply to: JohannC
Thanks a lot. yout Advice was wonderful (Y).
New Member
antonarap
Message 43 of 200 (5,295 Views)
05-30-2011 12:56 PM in reply to: gmijares
OK this is what worked for me:
Although I have a 64 bit version, I used the Command Prompt to navigate to directory C:\Windows\System32 I typed regsvr32 jscript.dll and  regsvr32 vbscript.dll. There is a space character between the comand (regsvr32) and the archive name (jscript.dll for example).
In order to navigate in a certeen directory with the command prompt use cd.. to move une directory up and cd NAME OF DIRECTORY to move one directory down (example: cd windows to move from c: to c:\windows, cd.. to move from c:\windows to c:smileyhappy:
This way the activation screen was displayed correctly.
New Member
Petrit10
Message 44 of 200 (5,141 Views)
06-18-2011 08:29 AM in reply to: govy86
Thank you for helping us.I activated with succes but something have done wrong because when click two times the icon the programm doesn't open.Please ,help me to get a choise.
Member
danblukk
Message 45 of 200 (5,089 Views)
06-23-2011 05:48 PM in reply to: gmijares
My 3D max 2011 worked fine unitil i had to format my pc and reinstall everything now i get the white screen licence thing. But mine sounds a little different to the rest. I get a small plane white box, dont even get the chane to click activate, but get this, if I open task manager and end the task, the activator windows comes up, can click activate and then it all works as normal, all radio buttons show, can click continue to activate my code but then the comuter gets on with the end task request and closes it. How annoying is that. Tried all solutions, mutiple browsers, reg edits, cmd prompts, nothing works.
Any advice anyone?
JarretDD
Message 46 of 200 (5,045 Views)
06-25-2011 07:56 PM in reply to: danblukk
Did you try the adding-the-tag-to-the-html solution on the first page?
Strange how you can almost continue with the activation is windows thinks the task has ended, but initially it is still blocked, for some reason. Since you've tried all the other solutions, adding the <!-- saved from url=(0016)http://localhost --> tag might help, as described on page 1 here.
New Member
eurgbp2011
Message 47 of 200 (5,042 Views)
06-26-2011 04:26 AM in reply to: gmijares
same problem on firefox 4 and win7 x64
New Member
mdm6533
Message 48 of 200 (4,992 Views)
Re: Blank Activation Screen -<{ THIS WORKS }>-
06-29-2011 05:18 PM in reply to: dejanxp
     Hey, just wanted to give a big thanks to ya for this help!  I know nothing of HTML scripting or editing, but followed your instructions (and thanks for the pics, definitely helped since I'm a visual learner), and on the next try to activate, all went well and was done in seconds:smileyvery-happy:  Can't tell ya how relieved I am now!
P.S.-  Running Win XP SP3 with Internet Explorer
New Member
whiterabbit77
Message 49 of 200 (4,923 Views)
07-07-2011 06:51 AM in reply to: gmijares
hi all,
i'm getting the same problem but i'm using mozilla firefox, any instructions on how to fix it within that?
cheers
New Member
Th10
Message 50 of 200 (4,909 Views)
07-08-2011 04:32 AM in reply to: JohannC
thhaaaaaaaaaaaaankkk youuu verry verry much your way work like magic but you know there is one little problem . it's not "'HKEY_CURRENT_USER/Software/Microsoft/Internet Settings/Zones' it's "HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Internet Settings\Zones"
at least that's what work for me but like you said just delete file "L" and it woooooooooooorkkkkkk
thaaank youu veryy veryyy verryyy much
and for more help use that link
http://usa.autodesk.com/adsk/servlet/ps/dl/item?linkID=9240617&id=6404339&siteID=123112
