Installation & Licensing
New Member
Xrispie
Message 31 of 213 (11,333 Views)
Re: Blank Activation Screen
03-29-2011 05:21 AM in reply to: JarretDD
This is how I fixed it.
Rigth click the white box.... select properties...... copy the web address it is trying to reach.   Open a browser window and paste it in. It should work just like a normal web address at that point and should not give you any issues.  I used google chrome and still worked fine.
I hope this helps any still with this problem.
~X~
JarretDD
Message 32 of 213 (11,302 Views)
03-31-2011 08:08 AM in reply to: Xrispie
That's probably because your chrome activex settings are different than your IE ones. The activation screen is normally opening the html in the pc's default browser, which is IE.
New Member
Inciong87
Message 33 of 213 (11,164 Views)
04-13-2011 05:39 AM in reply to: Xrispie
What do you mean by clicking the white box? can u explain its destination or path? i did all the things that they recommended and sadly the activation is still blank :smileysad: this is the only thing that i ddnt do. but your theory enlighten my hope :smileyvery-happy: pls reply ASAP... thank you and more power MR. ~X~
Member
RandyL
Message 34 of 213 (11,162 Views)
04-13-2011 06:09 AM in reply to: Inciong87
My only solution to the problem was to format my hard drive and reinstall windows. The Autodesk tech support kept referring me to the forum and Knowledge database which i had already gone thru thoroughly.
Active Member
glats
Message 35 of 213 (11,154 Views)
04-13-2011 07:41 AM in reply to: Xrispie
exactly what i've been saying all along  ...  re format re install windows  and install Autocad  .....
One of the problems i found is that there seems to be a conflict between Autocad and Google Chrome internet browser ...
anyone had a problem connecting to the interner within AutoCAD 2012 ... ??
JarretDD
Message 36 of 213 (11,150 Views)
04-13-2011 09:49 AM in reply to: Xrispie
The directory for the white box (the activation screen) is
C:\Program Files\Common Files\Autodesk Shared\AdLM\R1\en-US\Webdepot
...where the registry HTMLs are stored. These are the pages that the blank screen shows on.
Open the RTBeginReg.html in a text editor like notepad. Add the following line of code below the <html> line.
<!-- saved from url=(0016)http://localhost -->
This marks the page as SAFE. Save and you should be able to enter your code and stuff.
Member
RandyL
Message 37 of 213 (11,147 Views)
04-13-2011 10:04 AM in reply to: JarretDD
i had tried that and it still didn't work. the computer i use doesn't have internet at all so it didn't even have chrome.
New Member
shannon_set
Message 38 of 213 (11,103 Views)
04-15-2011 08:33 PM in reply to: JarretDD
Tried this and managed to get a screen up................!
But got a ("An error has occured in the script on this page.") message after I put in my activation code.
So frustrating, :smileymad:
Driving me nuts.
JarretDD
Message 39 of 213 (11,057 Views)
04-18-2011 05:17 AM in reply to: Xrispie
If that worked one one screen, great! Try putting the tag into the other htmls, specifically the one that comes after the code submission.
Product Support
avto
Message 40 of 213 (10,728 Views)
05-13-2011 03:09 PM in reply to: JarretDD
All known workarounds against this issue is listed in TS1053941, and I can only add that in some instances granting Full Control access permission to Everyone Group on C:\Program Files\Common Files\Autodesk Shared\AdLM\R4\en-US\Webdepot folder, resolved the issue.
Avto
Avto Chachava
Autodesk Product Support
