Installation & Licensing
Active Member
glats
Message 11 of 208 (13,300 Views)
Re: Blank Activation Screen
01-11-2011 12:20 AM in reply to: JohannC
Blank Activation Screen ...Endows XP
Thanks for the replies .... And the simplest way to solve the blank screen issue is do what I did. Reformat the hard disk, put on the security and then the software and it worked first time...
One thing i noticed though was my default browser was Chrome and for some reason it wouldn't "allow" the activation screen to connect to the net  ... and yet with Internet Explorer it sailed through
something worth thinking about
New Member
IroningMan
Message 12 of 208 (13,207 Views)
01-13-2011 07:04 AM in reply to: gmijares
Solution for me:
Adding the htmal strings to multiple files (I just kept adding until it worked) and registering online (through a browser and not the product)
Software works fine!
Thanks for the html tips!
New Member
frederico_710
Message 13 of 208 (13,171 Views)
01-13-2011 05:02 PM in reply to: JarretDD
hi!
I've done everything that you said, but i'm still dont guet it. it always show the blank screen. man can u help me? please!
New Member
JohannC
Message 14 of 208 (13,161 Views)
01-13-2011 09:12 PM in reply to: glats
A quick and easy way to fix this not with just AutoCad but if you have the same problem with other programs, like bitdefender and your windows gadgets, press & hold start button on key board and press 'R' , type in 'regedit' go to 'HKEY_CURRENT_USER, Software, Microsoft, Internet Settings, Zones' you will see under Zones are six files each named 'L' '0' '1' '2' '3' '4',  delete the file named 'L', that is the activex problem, you can uninstall it from your PC but these are "parasite" files that stay in the system. Problem solved quick and easy.
New Member
bigpoppa1978
Message 15 of 208 (13,044 Views)
01-17-2011 04:25 PM in reply to: gmijares
O.k this might sound stupid but I did all the steps you previously said and I tried to edit the html document and it had an access denied window open when I tried to save it.
New Member
bigpoppa1978
Message 16 of 208 (13,043 Views)
01-17-2011 04:28 PM in reply to: gmijares
Is anyone running Autocad on windows 7 or would that make any difference
New Member
designer217
Message 17 of 208 (13,034 Views)
01-17-2011 07:01 PM in reply to: JarretDD
thanks, man.  the first one worked for me.
New Member
20041383
Message 18 of 208 (12,991 Views)
01-18-2011 12:00 PM in reply to: glats
worked for me... thanks alot :smileywink:
New Member
Zed90
Message 19 of 208 (12,978 Views)
01-18-2011 03:10 PM in reply to: JarretDD
Well i tried editing the RTBeginReg file with notepad (see attachment 1). When i tried to save the file i got an error message (see attachment 2). help please.
JarretDD
Message 20 of 208 (12,918 Views)
01-19-2011 09:07 AM in reply to: Zed90
Right-click the HTML and make sure you have the permission to edit it. If you are admin, allow the user full control.
And... maybe not have the blank activation screen open when you edit it? That could also help.
