Installation & Licensing
164 Views, 1 Reply
BEWARE! Install Hangs...
On an 2002 deployment, sometimes the install hangs on an NT4 client.
This is because the VOLO VIEW EXPRESS portion of the install hangs.
This always was a standalone VOLO VIEW EXPRESS issue (TS65350).
Now this same issue has made it's way into the network install.
Running "setup.exe debug" has no effect when running the deploy setup (this
"debug" switch is not passed on to the vvesetup.exe).
The above hosed my 3 machines' registries so bad that I had to reformat them
if I wanted any AutoCAD on them.
This could have been avoided 2 ways...
1.) Fix the VOLO VIEW installation problem.
2.) Don't include VOLO VIEW in a COMPACT install. (This makes a lot of IS
people angry).
My fix was a CUSTOM install, and just to be sure, it wasn't a silent
install.
1 REPLY 1
We ran into the same problem. I like the custom install, just eliminating the Voloview. However, we found another solution to get you rolling again once the install hangs. Go to your Task Manager and end the task called _INSO432_MP. Be patient, and after a couple of seconds (minutes?) the install process will complete.
Guy
Administrator Productivity
