Installation & Licensing
131 Kudos
Post 1 of 5
BDS Ultimate AutoCAD MEP 2013 instillation failure
321 Views, 4 Replies
01-15-2013 04:25 PM
Hello - I have been trying to install AutoCAD MEP 2013 and cannot get it to work - I will post the log file.
Any ideas???
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
Product Support
30 Kudos
Post 2 of 5
Re: BDS Ultimate AutoCAD MEP 2013 instillation failure
01-16-2013 09:27 PM in reply to: LisaDrago
Try this solution.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Emily Xu
904 Kudos
Post 3 of 5
01-17-2013 08:13 AM in reply to: LisaDrago
I have noticed a lot of the AutoCAD vertical failures have to do with the fact that other flavors of AutoCAD are already installed.  Since many of them apparently install into the native \AutoCAD 2013\ folder, subsequent installs fail.  I noticed this when trying to install Mechanical 2013 when AutoCAD 2013 was already installed.  It failed.  When I removed AutoCAD 2013, it installed.  So see if you have any other verticals installed first and go from there.
131 Kudos
Post 4 of 5
01-17-2013 01:04 PM in reply to: TravisNave
I tried unloading the service pack and it still did not install - I can try removing autocad 2013 to see if it will work...
but then I am thinking 2014 should be out shortly - is it worth the trouble?
LD
904 Kudos
Post 5 of 5
01-17-2013 02:04 PM in reply to: LisaDrago
I hear ya.  I literally just had a user rename their existing AutoCAD 2013 folder to something else and it installed.  Might be worth a shot.
