Installation & Licensing
New Member
SzabuniaT
Message 1 of 5 (497 Views)
Batch install - Waiting for install to finish
497 Views, 4 Replies
12-04-2013 04:37 AM
I'm trying to install the Autodesk2013 Suite using this batch
@echo off
title Installing Autodesk Suite then logging off....
NET USE \\directory /user:********\****** ****** /persistent:YES
ECHO "Installing Autodesk Suite. This workstation will log off automatically when installation is complete."
START /WAIT /B "" "....\Setup.exe" /qb /I \AutoDesk2013.ini /language en-us
ECHO "Finished"
TIMEOUT /T 10
SHUTDOWN /l /f
EXIT
It initialises the install perfectly fine but it isn't waiting until it's finished, instantly moves on. Does this Setup invoke msiexec or something along those lines so the /WAIT doesn't work? If so, is there any way around it because we need to wait until it's finished to be able to log off the account.
Thanks in advance.
Employee
DannyHubbard
Message 2 of 5 (489 Views)
Re: Batch install - Waiting for install to finish
12-04-2013 07:22 AM in reply to: SzabuniaT
You should just need to add a /W switch to the Setup to get it to wait for the install to finish.
Something like,
START /WAIT /B "" "....\Setup.exe" /w /qb /I \AutoDesk2013.ini /language en-us
Danny
Danny Hubbard
QA Analyst
New Member
SzabuniaT
Message 3 of 5 (485 Views)
12-04-2013 08:01 AM in reply to: DannyHubbard
That didn't work, from what I gathered it's because the Setup.exe launches a separate installer  Here's a workaround that does, little bit hacky though.
@echo off title Installing Autodesk Suite then logging off....
NET USE \\**** /user:*****\***** ******** /persistent:YES
START /B "" "\AdminImage\Setup.exe" /qb /I \AdminImage\AutoDesk2013.ini /language en-us
TIMEOUT /T 10
SETLOCAL
SET TARGET=Setup.exe @ECHO Started!
:LOOP
ping -5 2 localhost >NUL FOR /F %%T IN ('tasklist.exe /FI "IMAGENAME eq %TARGET%"') DO (   SET FOUND=0   IF "%%~T"=="%TARGET%" SET FOUND=1 )
IF %FOUND%==1 GOTO :LOOP
ECHO "Finished"
TIMEOUT /T 10
SHUTDOWN /l /f
EXIT
Employee
DannyHubbard
Message 4 of 5 (481 Views)
12-04-2013 10:02 AM in reply to: SzabuniaT
A few other options would be to try the following.
CALL "" "....\Setup.exe" /w /qb /I \AutoDesk2013.ini /language en-us
Or since it appears you have already created a deployment you could just run the shortcut link for the deployment with something like.
CALL "\\server_name\share_name\deployment_folder\deployment_name.lnk" /w
Danny
Danny Hubbard
QA Analyst
New Member
sara.witherow
Message 5 of 5 (19 Views)
08-26-2014 07:39 AM in reply to: DannyHubbard
Thanks Danny.  It looks like the CALL is holding the batch file.
:smileyhappy:
Sara
Arlington County Schools
Arlington, VA
