Installation & Licensing
Basic info for Install of 2013
2 REPLIES 2
Chris-Draw
294 Views, 2 Replies
Can you tell me where to find the basic requirements BEFORE downloading the new release?
What minimum spec PC is required, do I uninstall 2012 first using the quick uninstall for Autodesk products?
How long does it take for product suite ultiimate?
best rgds CHRIS
CjWard
2 REPLIES 2
TravisNave
in reply to: Chris-Draw
Installing the entire suite can be as little as 45 minutes to as much as 4 hours depending on the speed of your machine and the options you choose.  You do not need to uninstall the 2012 suite first as they will live side-by-side just fine.  You may need to however on the content center and material library databases, however.
http://usa.autodesk.com/adsk/servlet/pc/index?siteID=123112&id=16491127
System requirements are different for each program in the suite.  As long as you meet the requirements for the most intensive programs, i.e. Inventor, Maya, then you should be fine.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Chris-Draw
in reply to: TravisNave
Thank you Guru, I'll give it a try on one machine, I normally have my CAD dealer install for me, but all UK CAD dealers have doubled their prices. Best rgds CHRIS
CjWard
Administrator Productivity
