Hi, I had install Autocad 2013 and Structural Detailing 2015 , because of a problem I decided to Uninstall SD2015 by Your Uninstaller! but both of this program deleted and then I cant install none of them. i have an error that says please install Material library before Base Image but i had installed Material but this error persist, I had try many ways , the same as manual completely delete autodesk products , using microsoft fix , and every solution that i had find for this problem, what should I do to resolve this problem? i cant install Base Image Library !
