Installation & Licensing
Backburner not in 2014 Autodesk Entertainment Suite
1 REPLY 1
mattsimecek
780 Views, 1 Reply
after installing the 2014 Entertainment Suite i noticed there is no Backburner.
usually this is listed below the 3ds Max pulldown during install.
does anyone with the Suite have the same issue?
1 REPLY 1
There is an error in the ‘Install EXE Sequence’ in the setup.ini.
You can manually invoke the setup by the following:
*From USB: Open <USBDrive>\x64\Backburner\.  And right click ‘BackburnerCIF.exe’, select run as Administrator to install.
*From Web Download: Open the location where you specified the installer to extract (Typically C:\Autodesk).  Open, c:\Autodesk\<Product>\x64\BackBurner\.  And right click ‘BackburnerCIF.exe’, select run as Administrator to install.
Hope this helps,
Cheers
Administrator Productivity
