Installation & Licensing
Autodest Revit 2014 installation errors.. Result=1619 (with log) PLZ HELP!!!
2 REPLIES 2
bobojj
310 Views, 2 Replies
2014/1/27:23:56:57    user    USER-PC    === Setup started on USER-PC by user ===
2014/1/27:23:56:57    user    USER-PC    Path_Length: 149
2014/1/27:23:56:57    user    USER-PC    Current Directory C:\Autodesk\Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US
2014/1/27:23:56:57    user    USER-PC    Launch
2014/1/27:23:56:57    user    USER-PC    CommandLine    /url "http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/Autodesk_Revit_2014_English_Win_32-64bit_wi_en-... /SN 900-44676136 /PK 829F1 /student  /akamai /auth authparam /sid SESSION_ID
2014/1/27:23:56:57    user    USER-PC    Current Directory C:\Users\user\AppData\Local\Temp\_AI6374.tmp
2014/1/27:23:57:09    user    USER-PC    === Setup ended ===
2014/1/27:23:56:58    user    USER-PC    === Setup started on USER-PC by user ===
2014/1/27:23:56:58    user    USER-PC    Path_Length: 149
2014/1/27:23:56:58    user    USER-PC    Current Directory C:\Users\user\AppData\Local\Temp\_AI6374.tmp
2014/1/27:23:56:58    user    USER-PC    Launch
2014/1/27:23:57:06    user    USER-PC    Download Error    Connection has expired. Please reconnect to site.    SETUP_CONFIG    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/Autodesk_Revit_2014_English_Win_32-64bit_wi_en-...
2014/1/27:23:57:06    user    USER-PC    Connection has expired. Please reconnect to site.2014/1/27:23:57:10    user    USER-PC    === Setup ended ===
2014/1/27:23:57:28    user    USER-PC    === Setup started on USER-PC by user ===
2014/1/27:23:57:28    user    USER-PC    Path_Length: 149
2014/1/27:23:57:28    user    USER-PC    Current Directory C:\Autodesk\Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US
2014/1/27:23:57:28    user    USER-PC    Launch
2014/1/27:23:57:28    user    USER-PC    CommandLine    /url "http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/Autodesk_Revit_2014_English_Win_32-64bit_wi_en-... /SN 900-44676136 /PK 829F1 /student  /akamai /auth authparam /sid SESSION_ID
2014/1/27:23:57:28    user    USER-PC    Current Directory C:\Users\user\AppData\Local\Temp\_AID604.tmp
2014/1/27:23:57:54    user    USER-PC    === Setup ended ===
2014/1/27:23:57:32    user    USER-PC    === Setup started on USER-PC by user ===
2014/1/27:23:57:32    user    USER-PC    Path_Length: 149
2014/1/27:23:57:32    user    USER-PC    Current Directory C:\Users\user\AppData\Local\Temp\_AID604.tmp
2014/1/27:23:57:32    user    USER-PC    Launch
2014/1/27:23:57:34    user    USER-PC    Download    Play    SETUP_CONFIG    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/SETUP_x6...
2014/1/27:23:57:53    user    USER-PC    Download    Complete    SETUP_CONFIG    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/SETUP_x6...
2014/1/27:23:57:53    user    USER-PC    Install    CustomCallback    Info    Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\user\AppData\Local\Temp\_AID604.tmp\Setup\RevitSetup.dll
2014/1/27:23:57:53    user    USER-PC    Install    CustomCallback    Info    Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/1/27:23:57:53    user    USER-PC    PageOpen    LaunchDialog
2014/1/28:00:00:38    user    USER-PC    PageOpen    LicenseDialog
2014/1/28:00:01:08    user    USER-PC    PageOpen    ProductInfoDialog
2014/1/28:00:01:08    user    USER-PC    PageOpen    ProductSelectionDialog2
2014/1/28:00:01:16    user    USER-PC    PageOpen    FullProgressDialog
2014/1/28:00:01:17    user    USER-PC    Download    Play    VCREDIST2005X86    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/VCREDIST...
2014/1/28:00:01:19    user    USER-PC    Download    Complete    VCREDIST2005X86    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/VCREDIST...
2014/1/28:00:01:19    user    USER-PC    Installing Microsoft Visual C++ 2005 Redistributable (x86): "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\x86\VCRedist\2005\vcredist_x86.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\user\AppData\Local\Temp\vcredist_x86_2005.log"" "
2014/1/28:00:01:23    user    USER-PC    Install    Microsoft Visual C++ 2005 Redistributable (x86)    Succeeded
2014/1/28:00:01:23    user    USER-PC    Download    Play    VCREDIST2005X64    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/VCREDIST...
2014/1/28:00:01:25    user    USER-PC    Download    Complete    VCREDIST2005X64    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/VCREDIST...
2014/1/28:00:01:25    user    USER-PC    Installing Microsoft Visual C++ 2005 Redistributable (x64): "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\x64\VCRedist\2005\vcredist_x64.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\user\AppData\Local\Temp\vcredist_x64_2005.log"" "
2014/1/28:00:01:28    user    USER-PC    Install    Microsoft Visual C++ 2005 Redistributable (x64)    Succeeded
2014/1/28:00:01:29    user    USER-PC    Download    Play    KB958314ATLX86    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/1/28:00:01:29    user    USER-PC    Download    Complete    KB958314ATLX86    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/1/28:00:01:29    user    USER-PC    Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x86):   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/1/28:00:01:36    user    USER-PC    Install    Microsoft Visual C++ 2008 KB958314 (ATL) (x86)    Succeeded
2014/1/28:00:01:37    user    USER-PC    Download    Play    KB958314MFCX86    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/1/28:00:01:40    user    USER-PC    Download    Complete    KB958314MFCX86    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/1/28:00:01:40    user    USER-PC    Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x86):   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/1/28:00:01:51    user    USER-PC    Install    Microsoft Visual C++ 2008 KB958314 (MFC) (x86)    Succeeded
2014/1/28:00:01:52    user    USER-PC    Download    Play    KB958314CRTX86    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/1/28:00:01:53    user    USER-PC    Download    Complete    KB958314CRTX86    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/1/28:00:01:53    user    USER-PC    Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x86):   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/1/28:00:02:02    user    USER-PC    Install    Microsoft Visual C++ 2008 KB958314 (CRT) (x86)    Succeeded
2014/1/28:00:02:03    user    USER-PC    Download    Play    KB958314OPENMPX86    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/1/28:00:02:03    user    USER-PC    Download    Complete    KB958314OPENMPX86    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/1/28:00:02:03    user    USER-PC    Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86):   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/1/28:00:02:12    user    USER-PC    Install    Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86)    Succeeded
2014/1/28:00:02:12    user    USER-PC    Download    Play    KB958314ATLX64    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/1/28:00:02:13    user    USER-PC    Download    Complete    KB958314ATLX64    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/1/28:00:02:13    user    USER-PC    Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x64):   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/1/28:00:02:18    user    USER-PC    Install    Microsoft Visual C++ 2008 KB958314 (ATL) (x64)    Succeeded
2014/1/28:00:02:19    user    USER-PC    Download    Play    KB958314MFCX64    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/1/28:00:02:22    user    USER-PC    Download    Complete    KB958314MFCX64    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/1/28:00:02:22    user    USER-PC    Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x64):   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/1/28:00:02:35    user    USER-PC    Install    Microsoft Visual C++ 2008 KB958314 (MFC) (x64)    Succeeded
2014/1/28:00:02:35    user    USER-PC    Download    Play    KB958314CRTX64    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/1/28:00:02:36    user    USER-PC    Download    Complete    KB958314CRTX64    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/1/28:00:02:36    user    USER-PC    Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x64):   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/1/28:00:02:45    user    USER-PC    Install    Microsoft Visual C++ 2008 KB958314 (CRT) (x64)    Succeeded
2014/1/28:00:02:45    user    USER-PC    Download    Play    KB958314OPENMPX64    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/1/28:00:02:46    user    USER-PC    Download    Complete    KB958314OPENMPX64    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/1/28:00:02:46    user    USER-PC    Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64):   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/1/28:00:02:53    user    USER-PC    Install    Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64)    Succeeded
2014/1/28:00:02:54    user    USER-PC    Download    Play    DIRECTX    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/DIRECTX....
2014/1/28:00:02:56    user    USER-PC    Download    Complete    DIRECTX    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/DIRECTX....
2014/1/28:00:02:56    user    USER-PC    Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2014/1/28:00:03:25    user    USER-PC    Install    DirectX® Runtime    Succeeded
2014/1/28:00:03:26    user    USER-PC    Download    Play    RVT2014    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/RVT2014_...
2014/1/28:00:07:09    user    USER-PC    Download Error    RVT2014    <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now?     http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/RVT2014_...
2014/1/28:00:07:39    user    USER-PC    Download Error    RVT2014    <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now?     http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/RVT2014_...
2014/1/28:00:10:55    user    USER-PC    Download    Complete    RVT2014    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/RVT2014_...
2014/1/28:00:11:06    user    USER-PC    Installing Autodesk® Revit® 2014:  TRANSFORMS="C:\Autodesk\WI\Autodesk Revit 2014\x64\en-us\RVT2014\RVT2014.mst;C:\Users\user\AppData\Local\Temp\_AID604.tmp\x64\RVT2014\RVT2014-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" INSTALLDIR="Z:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/1/28:00:18:50    user    USER-PC    Install    Autodesk® Revit® 2014    Succeeded
2014/1/28:00:18:50    user    USER-PC    Download    Play    RVT2014_en-us    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/RVT2014_...
2014/1/28:00:18:57    user    USER-PC    Download    Aborted    RVT2014_en-us    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/RVT2014_...
2014/1/28:00:18:57    user    USER-PC    Install    Autodesk® Revit® 2014 Language Pack    Failed    Download Failed, Installation aborted, Result=1603
2014/1/28:00:23:22    user    USER-PC    Rollback    Autodesk® Revit® 2014    Succeeded
2014/1/28:00:23:22    user    USER-PC    Rollback    DirectX® Runtime    Failed    Failure is ignored, Result=1619
2014/1/28:00:23:28    user    USER-PC    Rollback    Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64)    Succeeded
2014/1/28:00:23:32    user    USER-PC    Rollback    Microsoft Visual C++ 2008 KB958314 (CRT) (x64)    Succeeded
2014/1/28:00:23:36    user    USER-PC    Rollback    Microsoft Visual C++ 2008 KB958314 (MFC) (x64)    Succeeded
2014/1/28:00:23:39    user    USER-PC    Rollback    Microsoft Visual C++ 2008 KB958314 (ATL) (x64)    Succeeded
2014/1/28:00:23:43    user    USER-PC    Rollback    Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86)    Succeeded
2014/1/28:00:23:48    user    USER-PC    Rollback    Microsoft Visual C++ 2008 KB958314 (CRT) (x86)    Succeeded
2014/1/28:00:23:52    user    USER-PC    Rollback    Microsoft Visual C++ 2008 KB958314 (MFC) (x86)    Succeeded
2014/1/28:00:23:55    user    USER-PC    Rollback    Microsoft Visual C++ 2008 KB958314 (ATL) (x86)    Succeeded
2014/1/28:00:23:56    user    USER-PC    Rollback    Microsoft Visual C++ 2005 Redistributable (x64)    Failed    Installation aborted, Result=1619
2014/1/28:00:23:56    user    USER-PC    Rollback    Microsoft Visual C++ 2005 Redistributable (x86)    Failed    Installation aborted, Result=1619
2014/1/28:00:23:56    user    USER-PC    PageOpen    InstallCompleteDialog
2014/1/28:00:24:20    user    USER-PC    === Setup ended ===
2014/1/28:00:31:28    user    USER-PC    === Setup started on USER-PC by user ===
2014/1/28:00:31:28    user    USER-PC    Path_Length: 149
2014/1/28:00:31:28    user    USER-PC    Current Directory C:\Autodesk\Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US
2014/1/28:00:31:28    user    USER-PC    Launch
2014/1/28:00:31:28    user    USER-PC    CommandLine    /url "http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/Autodesk_Revit_2014_English_Win_32-64bit_wi_en-... /SN 900-44676136 /PK 829F1 /student  /akamai /auth authparam /sid SESSION_ID
2014/1/28:00:31:28    user    USER-PC    Current Directory C:\Users\user\AppData\Local\Temp\_AIFB7E.tmp
2014/1/28:00:31:37    user    USER-PC    === Setup ended ===
2014/1/28:00:31:29    user    USER-PC    === Setup started on USER-PC by user ===
2014/1/28:00:31:29    user    USER-PC    Path_Length: 149
2014/1/28:00:31:29    user    USER-PC    Current Directory C:\Users\user\AppData\Local\Temp\_AIFB7E.tmp
2014/1/28:00:31:29    user    USER-PC    Launch
2014/1/28:00:31:36    user    USER-PC    Download    Skipped    SETUP_CONFIG    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/SETUP_x6...
2014/1/28:00:31:36    user    USER-PC    Install    CustomCallback    Info    Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\user\AppData\Local\Temp\_AIFB7E.tmp\Setup\RevitSetup.dll
2014/1/28:00:31:36    user    USER-PC    Install    CustomCallback    Info    Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/1/28:00:31:36    user    USER-PC    PageOpen    LaunchDialog
2014/1/28:00:34:19    user    USER-PC    PageOpen    LicenseDialog
2014/1/28:00:34:29    user    USER-PC    PageOpen    ProductInfoDialog
2014/1/28:00:34:29    user    USER-PC    PageOpen    ProductSelectionDialog2
2014/1/28:00:34:48    user    USER-PC    PageOpen    FullProgressDialog
2014/1/28:00:34:49    user    USER-PC    Download    Skipped    KB958314ATLX86    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/1/28:00:34:49    user    USER-PC    Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x86):   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/1/28:00:34:52    user    USER-PC    Install    Microsoft Visual C++ 2008 KB958314 (ATL) (x86)    Succeeded
2014/1/28:00:34:52    user    USER-PC    Download    Skipped    KB958314MFCX86    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/1/28:00:34:52    user    USER-PC    Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x86):   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/1/28:00:34:59    user    USER-PC    Install    Microsoft Visual C++ 2008 KB958314 (MFC) (x86)    Succeeded
2014/1/28:00:35:00    user    USER-PC    Download    Skipped    KB958314CRTX86    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/1/28:00:35:00    user    USER-PC    Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x86):   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/1/28:00:35:06    user    USER-PC    Install    Microsoft Visual C++ 2008 KB958314 (CRT) (x86)    Succeeded
2014/1/28:00:35:06    user    USER-PC    Download    Skipped    KB958314OPENMPX86    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/1/28:00:35:06    user    USER-PC    Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86):   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/1/28:00:35:12    user    USER-PC    Install    Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86)    Succeeded
2014/1/28:00:35:12    user    USER-PC    Download    Skipped    KB958314ATLX64    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/1/28:00:35:12    user    USER-PC    Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x64):   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/1/28:00:35:15    user    USER-PC    Install    Microsoft Visual C++ 2008 KB958314 (ATL) (x64)    Succeeded
2014/1/28:00:35:16    user    USER-PC    Download    Skipped    KB958314MFCX64    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/1/28:00:35:16    user    USER-PC    Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x64):   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/1/28:00:35:24    user    USER-PC    Install    Microsoft Visual C++ 2008 KB958314 (MFC) (x64)    Succeeded
2014/1/28:00:35:24    user    USER-PC    Download    Skipped    KB958314CRTX64    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/1/28:00:35:24    user    USER-PC    Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x64):   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/1/28:00:35:30    user    USER-PC    Install    Microsoft Visual C++ 2008 KB958314 (CRT) (x64)    Succeeded
2014/1/28:00:35:30    user    USER-PC    Download    Skipped    KB958314OPENMPX64    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/1/28:00:35:30    user    USER-PC    Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64):   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/1/28:00:35:36    user    USER-PC    Install    Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64)    Succeeded
2014/1/28:00:35:36    user    USER-PC    Download    Skipped    DIRECTX    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/DIRECTX....
2014/1/28:00:35:36    user    USER-PC    Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2014/1/28:00:36:09    user    USER-PC    Install    DirectX® Runtime    Succeeded
2014/1/28:00:36:09    user    USER-PC    Download    Skipped    RVT2014    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/RVT2014_...
2014/1/28:00:36:10    user    USER-PC    Installing Autodesk® Revit® 2014:  TRANSFORMS="C:\Autodesk\WI\Autodesk Revit 2014\x64\en-us\RVT2014\RVT2014.mst;C:\Users\user\AppData\Local\Temp\_AIFB7E.tmp\x64\RVT2014\RVT2014-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" INSTALLDIR="Z:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/1/28:00:44:37    user    USER-PC    Install    Autodesk® Revit® 2014    Succeeded
2014/1/28:00:44:38    user    USER-PC    Download    Play    RVT2014_en-us    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/RVT2014_...
2014/1/28:00:44:46    user    USER-PC    Download    Complete    RVT2014_en-us    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/RVT2014_...
2014/1/28:00:44:47    user    USER-PC    Installing Autodesk® Revit® 2014 Language Pack:  TRANSFORMS="C:\Users\user\AppData\Local\Temp\_AIFB7E.tmp\_la2EC5.tmp.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;" MUIHIDEARP=1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" INSTALLDIR="Z:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/1/28:00:44:56    user    USER-PC    Install    Autodesk® Revit® 2014 Language Pack    Succeeded
2014/1/28:00:44:56    user    USER-PC    Installing Autodesk Workflows 2014:   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/1/28:00:45:02    user    USER-PC    Install    Autodesk Workflows 2014    Succeeded
2014/1/28:00:45:03    user    USER-PC    Download    Play    CMILL2014    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/CMILL201...
2014/1/28:00:46:37    user    USER-PC    Download    Complete    CMILL2014    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/CMILL201...
2014/1/28:00:46:37    user    USER-PC    Installing Autodesk Material Library 2014 - Low Image Library:   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),{644F9B19-A462-499C-BF4D-300ABC2A28B1},;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/1/28:00:46:56    user    USER-PC    Install    Autodesk Material Library 2014 - Low Image Library    Succeeded
2014/1/28:00:46:57    user    USER-PC    Download    Play    CMILM2014    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/CMILM201...
2014/1/28:00:49:32    user    USER-PC    Download Error    CMILM2014    <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now?     http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/CMILM201...
2014/1/28:00:54:59    user    USER-PC    Download    Aborted    CMILM2014    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/CMILM201...
2014/1/28:00:54:59    user    USER-PC    Install    Autodesk Material Library 2014 - Medium Image Library    Failed    Download Failed, Installation aborted, Result=1603
2014/1/28:00:55:17    user    USER-PC    Rollback    Autodesk Material Library 2014 - Low Image Library    Succeeded
2014/1/28:00:55:20    user    USER-PC    Rollback    Autodesk Workflows 2014    Succeeded
2014/1/28:00:55:31    user    USER-PC    Rollback    Autodesk® Revit® 2014 Language Pack    Succeeded
2014/1/28:01:00:02    user    USER-PC    Rollback    Autodesk® Revit® 2014    Succeeded
2014/1/28:01:00:02    user    USER-PC    Rollback    DirectX® Runtime    Failed    Failure is ignored, Result=1619
2014/1/28:01:00:09    user    USER-PC    Rollback    Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64)    Succeeded
2014/1/28:01:00:13    user    USER-PC    Rollback    Microsoft Visual C++ 2008 KB958314 (CRT) (x64)    Succeeded
2014/1/28:01:00:17    user    USER-PC    Rollback    Microsoft Visual C++ 2008 KB958314 (MFC) (x64)    Succeeded
2014/1/28:01:00:21    user    USER-PC    Rollback    Microsoft Visual C++ 2008 KB958314 (ATL) (x64)    Succeeded
2014/1/28:01:00:25    user    USER-PC    Rollback    Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86)    Succeeded
2014/1/28:01:00:30    user    USER-PC    Rollback    Microsoft Visual C++ 2008 KB958314 (CRT) (x86)    Succeeded
2014/1/28:01:00:35    user    USER-PC    Rollback    Microsoft Visual C++ 2008 KB958314 (MFC) (x86)    Succeeded
2014/1/28:01:00:39    user    USER-PC    Rollback    Microsoft Visual C++ 2008 KB958314 (ATL) (x86)    Succeeded
2014/1/28:01:00:39    user    USER-PC    PageOpen    InstallCompleteDialog
2014/1/28:01:00:57    user    USER-PC    === Setup ended ===
2014/2/3:23:13:28    user    USER-PC    === Setup started on USER-PC by user ===
2014/2/3:23:13:28    user    USER-PC    Path_Length: 149
2014/2/3:23:13:28    user    USER-PC    Current Directory C:\Autodesk\Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US
2014/2/3:23:13:28    user    USER-PC    Launch
2014/2/3:23:13:28    user    USER-PC    CommandLine    /url "http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/Autodesk_Revit_2014_English_Win_32-64bit_wi_en-... /SN 900-44676136 /PK 829F1 /student  /akamai /auth authparam /sid SESSION_ID
2014/2/3:23:13:28    user    USER-PC    Current Directory C:\Users\user\AppData\Local\Temp\_AIB418.tmp
2014/2/3:23:13:34    user    USER-PC    === Setup ended ===
2014/2/3:23:13:29    user    USER-PC    === Setup started on USER-PC by user ===
2014/2/3:23:13:29    user    USER-PC    Path_Length: 149
2014/2/3:23:13:29    user    USER-PC    Current Directory C:\Users\user\AppData\Local\Temp\_AIB418.tmp
2014/2/3:23:13:29    user    USER-PC    Launch
2014/2/3:23:13:32    user    USER-PC    Download    Skipped    SETUP_CONFIG    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/SETUP_x6...
2014/2/3:23:13:33    user    USER-PC    Install    CustomCallback    Info    Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\user\AppData\Local\Temp\_AIB418.tmp\Setup\RevitSetup.dll
2014/2/3:23:13:33    user    USER-PC    Install    CustomCallback    Info    Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/2/3:23:13:34    user    USER-PC    PageOpen    LaunchDialog
2014/2/4:00:42:59    user    USER-PC    === Setup started on USER-PC by user ===
2014/2/4:00:42:59    user    USER-PC    Path_Length: 149
2014/2/4:00:42:59    user    USER-PC    Current Directory C:\Autodesk\Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US
2014/2/4:00:42:59    user    USER-PC    Launch
2014/2/4:00:42:59    user    USER-PC    CommandLine    /url "http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US_S... /akamai /auth authparam /sid SESSION_ID
2014/2/4:00:42:59    user    USER-PC    Current Directory C:\Users\user\AppData\Local\Temp\_AIA50C.tmp
2014/2/4:00:43:27    user    USER-PC    === Setup ended ===
2014/2/4:00:43:01    user    USER-PC    === Setup started on USER-PC by user ===
2014/2/4:00:43:01    user    USER-PC    Path_Length: 149
2014/2/4:00:43:01    user    USER-PC    Current Directory C:\Users\user\AppData\Local\Temp\_AIA50C.tmp
2014/2/4:00:43:01    user    USER-PC    Launch
2014/2/4:00:43:03    user    USER-PC    Download    Play    SETUP_CONFIG    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/SETUP_x64.ta...
2014/2/4:00:43:25    user    USER-PC    Download    Complete    SETUP_CONFIG    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/SETUP_x64.ta...
2014/2/4:00:43:25    user    USER-PC    Install    CustomCallback    Info    Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\user\AppData\Local\Temp\_AIA50C.tmp\Setup\RevitSetup.dll
2014/2/4:00:43:25    user    USER-PC    Install    CustomCallback    Info    Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/2/4:00:43:27    user    USER-PC    PageOpen    LaunchDialog
2014/2/4:00:43:49    user    USER-PC    PageOpen    LicenseDialog
2014/2/4:00:44:46    user    USER-PC    PageOpen    ProductInfoDialog
2014/2/4:00:48:23    user    USER-PC    PageOpen    ProductSelectionDialog2
2014/2/4:00:49:05    user    USER-PC    === Setup ended ===
2014/2/4:00:54:38    user    USER-PC    === Setup started on USER-PC by user ===
2014/2/4:00:54:38    user    USER-PC    Path_Length: 149
2014/2/4:00:54:38    user    USER-PC    Current Directory C:\Autodesk\Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US
2014/2/4:00:54:38    user    USER-PC    Launch
2014/2/4:00:54:38    user    USER-PC    CommandLine    /url "http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/Autodesk_Revit_2014_English_Win_32-64bit_wi_en-... /SN 900-44676136 /PK 829F1 /student  /akamai /auth authparam /sid SESSION_ID
2014/2/4:00:54:38    user    USER-PC    Current Directory C:\Users\user\AppData\Local\Temp\_AI5374.tmp
2014/2/4:00:54:43    user    USER-PC    === Setup ended ===
2014/2/4:00:54:39    user    USER-PC    === Setup started on USER-PC by user ===
2014/2/4:00:54:39    user    USER-PC    Path_Length: 149
2014/2/4:00:54:39    user    USER-PC    Current Directory C:\Users\user\AppData\Local\Temp\_AI5374.tmp
2014/2/4:00:54:39    user    USER-PC    Launch
2014/2/4:00:54:43    user    USER-PC    Download    Skipped    SETUP_CONFIG    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/SETUP_x6...
2014/2/4:00:54:43    user    USER-PC    Install    CustomCallback    Info    Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\user\AppData\Local\Temp\_AI5374.tmp\Setup\RevitSetup.dll
2014/2/4:00:54:43    user    USER-PC    Install    CustomCallback    Info    Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/2/4:00:54:43    user    USER-PC    PageOpen    LaunchDialog
2014/2/7:18:49:19    user    USER-PC    === Setup started on USER-PC by user ===
2014/2/7:18:49:19    user    USER-PC    Path_Length: 149
2014/2/7:18:49:19    user    USER-PC    Current Directory C:\Autodesk\Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US
2014/2/7:18:49:19    user    USER-PC    Launch
2014/2/7:18:49:19    user    USER-PC    CommandLine    /url "http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US_S... /akamai /auth authparam /sid SESSION_ID
2014/2/7:18:49:19    user    USER-PC    Current Directory C:\Users\user\AppData\Local\Temp\_AIFC3D.tmp
2014/2/7:18:49:24    user    USER-PC    === Setup ended ===
2014/2/7:18:49:21    user    USER-PC    === Setup started on USER-PC by user ===
2014/2/7:18:49:21    user    USER-PC    Path_Length: 149
2014/2/7:18:49:21    user    USER-PC    Current Directory C:\Users\user\AppData\Local\Temp\_AIFC3D.tmp
2014/2/7:18:49:21    user    USER-PC    Launch
2014/2/7:18:49:23    user    USER-PC    Download    Skipped    SETUP_CONFIG    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/SETUP_x64.ta...
2014/2/7:18:49:23    user    USER-PC    Install    CustomCallback    Info    Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\user\AppData\Local\Temp\_AIFC3D.tmp\Setup\RevitSetup.dll
2014/2/7:18:49:23    user    USER-PC    Install    CustomCallback    Info    Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/2/7:18:49:23    user    USER-PC    PageOpen    LaunchDialog
2014/2/7:18:49:35    user    USER-PC    PageOpen    LicenseDialog
2014/2/7:18:49:38    user    USER-PC    PageOpen    ProductSelectionDialog2
2014/2/7:18:49:45    user    USER-PC    PageOpen    LicenseDialog
2014/2/7:18:49:46    user    USER-PC    PageOpen    LaunchDialog
2014/2/7:18:49:52    user    USER-PC    PageOpen    LicenseDialog
2014/2/7:18:49:56    user    USER-PC    PageOpen    ProductInfoDialog
2014/2/7:18:51:12    user    USER-PC    PageOpen    ProductSelectionDialog2
2014/2/7:18:51:57    user    USER-PC    PageOpen    FullProgressDialog
2014/2/7:18:51:57    user    USER-PC    Download    Play    DIRECTX    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/DIRECTX.tar....
2014/2/7:18:52:01    user    USER-PC    Download    Complete    DIRECTX    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/DIRECTX.tar....
2014/2/7:18:52:01    user    USER-PC    Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2014/2/7:18:52:51    user    USER-PC    Install    DirectX® Runtime    Succeeded
2014/2/7:18:52:51    user    USER-PC    Download    Play    RVT2014    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/RVT2014_x64....
2014/2/7:18:59:18    user    USER-PC    Download    Complete    RVT2014    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/RVT2014_x64....
2014/2/7:18:59:23    user    USER-PC    Installing Autodesk® Revit® 2014:  TRANSFORMS="C:\Autodesk\WI\Autodesk Revit 2014\x64\en-us\RVT2014\RVT2014.mst;C:\Users\user\AppData\Local\Temp\_AIFC3D.tmp\x64\RVT2014\RVT2014-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/2/7:19:07:37    user    USER-PC    Install    Autodesk® Revit® 2014    Succeeded
2014/2/7:19:07:38    user    USER-PC    Download    Play    RVT2014_en-us    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/RVT2014_x64_...
2014/2/7:19:07:56    user    USER-PC    Download    Complete    RVT2014_en-us    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/RVT2014_x64_...
2014/2/7:19:07:57    user    USER-PC    Installing Autodesk® Revit® 2014 Language Pack:  TRANSFORMS="C:\Users\user\AppData\Local\Temp\_AIFC3D.tmp\_la9A0.tmp.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;" MUIHIDEARP=1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/2/7:19:08:03    user    USER-PC    Install    Autodesk® Revit® 2014 Language Pack    Succeeded
2014/2/7:19:08:04    user    USER-PC    Installing Autodesk Workflows 2014:   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/2/7:19:08:18    user    USER-PC    Install    Autodesk Workflows 2014    Succeeded
2014/2/7:19:08:19    user    USER-PC    Download    Play    CMILL2014    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/CMILL2014.ta...
2014/2/7:19:10:07    user    USER-PC    Download    Complete    CMILL2014    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/CMILL2014.ta...
2014/2/7:19:10:07    user    USER-PC    Installing Autodesk Material Library 2014 - Low Image Library:   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),{644F9B19-A462-499C-BF4D-300ABC2A28B1},;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/2/7:19:10:41    user    USER-PC    Install    Autodesk Material Library 2014 - Low Image Library    Succeeded
2014/2/7:19:10:42    user    USER-PC    Download    Play    CMILM2014    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/CMILM2014.ta...
2014/2/7:19:17:14    user    USER-PC    Download    Aborted    CMILM2014    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/CMILM2014.ta...
2014/2/7:19:17:14    user    USER-PC    Install    Autodesk Material Library 2014 - Medium Image Library    Failed    Download Failed, Installation aborted, Result=1603
2014/2/7:19:17:40    user    USER-PC    Rollback    Autodesk Material Library 2014 - Low Image Library    Succeeded
2014/2/7:19:17:42    user    USER-PC    Rollback    Autodesk Workflows 2014    Succeeded
2014/2/7:19:17:57    user    USER-PC    Rollback    Autodesk® Revit® 2014 Language Pack    Succeeded
2014/2/7:19:21:49    user    USER-PC    Rollback    Autodesk® Revit® 2014    Succeeded
2014/2/7:19:21:49    user    USER-PC    Rollback    DirectX® Runtime    Failed    Failure is ignored, Result=1619
2014/2/7:19:21:50    user    USER-PC    PageOpen    InstallCompleteDialog
2014/2/7:19:35:55    user    USER-PC    === Setup ended ===
2014/2/7:19:41:12    user    USER-PC    === Setup started on USER-PC by user ===
2014/2/7:19:41:12    user    USER-PC    Path_Length: 149
2014/2/7:19:41:12    user    USER-PC    Current Directory C:\Autodesk\Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US
2014/2/7:19:41:12    user    USER-PC    Launch
2014/2/7:19:41:12    user    USER-PC    CommandLine    /url "http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US_S... /akamai /auth authparam /sid SESSION_ID
2014/2/7:19:41:12    user    USER-PC    Current Directory C:\Users\user\AppData\Local\Temp\_AI7F91.tmp
2014/2/7:19:41:22    user    USER-PC    === Setup ended ===
2014/2/7:19:41:14    user    USER-PC    === Setup started on USER-PC by user ===
2014/2/7:19:41:14    user    USER-PC    Path_Length: 149
2014/2/7:19:41:14    user    USER-PC    Current Directory C:\Users\user\AppData\Local\Temp\_AI7F91.tmp
2014/2/7:19:41:14    user    USER-PC    Launch
2014/2/7:19:41:21    user    USER-PC    Download    Skipped    SETUP_CONFIG    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/SETUP_x64.ta...
2014/2/7:19:41:21    user    USER-PC    Install    CustomCallback    Info    Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\user\AppData\Local\Temp\_AI7F91.tmp\Setup\RevitSetup.dll
2014/2/7:19:41:21    user    USER-PC    Install    CustomCallback    Info    Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/2/7:19:41:22    user    USER-PC    PageOpen    LaunchDialog
2014/2/7:19:41:27    user    USER-PC    PageOpen    LicenseDialog
2014/2/7:19:41:42    user    USER-PC    PageOpen    ProductInfoDialog
2014/2/7:20:32:34    user    USER-PC    === Setup started on USER-PC by user ===
2014/2/7:20:32:34    user    USER-PC    Path_Length: 149
2014/2/7:20:32:34    user    USER-PC    Current Directory C:\Autodesk\Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US
2014/2/7:20:32:34    user    USER-PC    Launch
2014/2/7:20:32:34    user    USER-PC    CommandLine    /url "http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/Autodesk_Revit_2014_English_Win_32-64bit_wi_en-... /SN 900-44676136 /PK 829F1 /student  /akamai /auth authparam /sid SESSION_ID
2014/2/7:20:32:34    user    USER-PC    Current Directory C:\Users\user\AppData\Local\Temp\_AI81B3.tmp
2014/2/7:20:32:51    user    USER-PC    === Setup ended ===
2014/2/7:20:32:38    user    USER-PC    === Setup started on USER-PC by user ===
2014/2/7:20:32:38    user    USER-PC    Path_Length: 149
2014/2/7:20:32:38    user    USER-PC    Current Directory C:\Users\user\AppData\Local\Temp\_AI81B3.tmp
2014/2/7:20:32:38    user    USER-PC    Launch
2014/2/7:20:32:49    user    USER-PC    Download    Skipped    SETUP_CONFIG    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/SETUP_x6...
2014/2/7:20:32:50    user    USER-PC    Install    CustomCallback    Info    Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\user\AppData\Local\Temp\_AI81B3.tmp\Setup\RevitSetup.dll
2014/2/7:20:32:50    user    USER-PC    Install    CustomCallback    Info    Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/2/7:20:32:51    user    USER-PC    PageOpen    LaunchDialog
2014/2/7:20:36:00    user    USER-PC    PageOpen    LicenseDialog
2014/2/7:20:36:15    user    USER-PC    PageOpen    ProductInfoDialog
2014/2/7:20:36:15    user    USER-PC    PageOpen    ProductSelectionDialog2
2014/2/7:20:36:51    user    USER-PC    PageOpen    FullProgressDialog
2014/2/7:20:36:51    user    USER-PC    Download    Skipped    DIRECTX    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/DIRECTX....
2014/2/7:20:36:51    user    USER-PC    Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2014/2/7:20:37:31    user    USER-PC    Install    DirectX® Runtime    Succeeded
2014/2/7:20:37:31    user    USER-PC    Download    Skipped    RVT2014    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/RVT2014_...
2014/2/7:20:37:35    user    USER-PC    Installing Autodesk® Revit® 2014:  TRANSFORMS="C:\Autodesk\WI\Autodesk Revit 2014\x64\en-us\RVT2014\RVT2014.mst;C:\Users\user\AppData\Local\Temp\_AI81B3.tmp\x64\RVT2014\RVT2014-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/2/7:20:45:31    user    USER-PC    Install    Autodesk® Revit® 2014    Succeeded
2014/2/7:20:45:32    user    USER-PC    Download    Skipped    RVT2014_en-us    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/RVT2014_...
2014/2/7:20:45:32    user    USER-PC    Installing Autodesk® Revit® 2014 Language Pack:  TRANSFORMS="C:\Users\user\AppData\Local\Temp\_AI81B3.tmp\_la63DE.tmp.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;" MUIHIDEARP=1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/2/7:20:45:49    user    USER-PC    Install    Autodesk® Revit® 2014 Language Pack    Succeeded
2014/2/7:20:45:49    user    USER-PC    Installing Autodesk Workflows 2014:   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/2/7:20:45:54    user    USER-PC    Install    Autodesk Workflows 2014    Succeeded
2014/2/7:20:45:54    user    USER-PC    Download    Skipped    CMILL2014    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/CMILL201...
2014/2/7:20:45:54    user    USER-PC    Installing Autodesk Material Library 2014 - Low Image Library:   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),{644F9B19-A462-499C-BF4D-300ABC2A28B1},;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/2/7:20:46:24    user    USER-PC    Install    Autodesk Material Library 2014 - Low Image Library    Succeeded
2014/2/7:20:46:24    user    USER-PC    Download    Play    CMILM2014    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/CMILM201...
2014/2/7:20:50:39    user    USER-PC    Download Error    CMILM2014    <B>No Response from Server</B>Please retry or download again from the website.    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/CMILM201...
2014/2/7:20:51:09    user    USER-PC    Download Error    CMILM2014    <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now?     http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/CMILM201...
2014/2/7:20:52:39    user    USER-PC    Download    Aborted    CMILM2014    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/CMILM201...
2014/2/7:20:52:39    user    USER-PC    Install    Autodesk Material Library 2014 - Medium Image Library    Failed    Download Failed, Installation aborted, Result=1603
2014/2/7:20:53:02    user    USER-PC    Rollback    Autodesk Material Library 2014 - Low Image Library    Succeeded
2014/2/7:20:53:05    user    USER-PC    Rollback    Autodesk Workflows 2014    Succeeded
2014/2/7:20:53:20    user    USER-PC    Rollback    Autodesk® Revit® 2014 Language Pack    Succeeded
2014/2/7:20:57:35    user    USER-PC    Rollback    Autodesk® Revit® 2014    Succeeded
2014/2/7:20:57:35    user    USER-PC    Rollback    DirectX® Runtime    Failed    Failure is ignored, Result=1619
2014/2/7:20:57:36    user    USER-PC    PageOpen    InstallCompleteDialog
2014/2/7:20:58:26    user    USER-PC    === Setup ended ===
2014/2/28:10:45:24    user    USER-PC    === Setup started on USER-PC by user ===
2014/2/28:10:45:24    user    USER-PC    Path_Length: 149
2014/2/28:10:45:24    user    USER-PC    Current Directory C:\Autodesk\Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US
2014/2/28:10:45:24    user    USER-PC    Launch
2014/2/28:10:45:24    user    USER-PC    CommandLine    /url "http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US_S... /akamai /auth authparam /sid SESSION_ID
2014/2/28:10:45:24    user    USER-PC    Current Directory C:\Users\user\AppData\Local\Temp\_AI5D7D.tmp
2014/2/28:10:45:30    user    USER-PC    === Setup ended ===
2014/2/28:10:45:26    user    USER-PC    === Setup started on USER-PC by user ===
2014/2/28:10:45:26    user    USER-PC    Path_Length: 149
2014/2/28:10:45:26    user    USER-PC    Current Directory C:\Users\user\AppData\Local\Temp\_AI5D7D.tmp
2014/2/28:10:45:26    user    USER-PC    Launch
2014/2/28:10:45:28    user    USER-PC    Download    Skipped    SETUP_CONFIG    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/SETUP_x64.ta...
2014/2/28:10:45:29    user    USER-PC    Install    CustomCallback    Info    Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\user\AppData\Local\Temp\_AI5D7D.tmp\Setup\RevitSetup.dll
2014/2/28:10:45:29    user    USER-PC    Install    CustomCallback    Info    Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/2/28:10:45:30    user    USER-PC    PageOpen    LaunchDialog
2014/2/28:10:45:41    user    USER-PC    PageOpen    LicenseDialog
2014/2/28:10:45:47    user    USER-PC    PageOpen    ProductInfoDialog
2014/2/28:10:46:56    user    USER-PC    PageOpen    ProductSelectionDialog2
2014/2/28:10:47:20    user    USER-PC    PageOpen    FullProgressDialog
2014/2/28:10:47:21    user    USER-PC    Download    Skipped    DIRECTX    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/DIRECTX.tar....
2014/2/28:10:47:21    user    USER-PC    Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2014/2/28:10:48:07    user    USER-PC    Install    DirectX® Runtime    Succeeded
2014/2/28:10:48:07    user    USER-PC    Download    Skipped    RVT2014    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/RVT2014_x64....
2014/2/28:10:48:11    user    USER-PC    Installing Autodesk® Revit® 2014:  TRANSFORMS="C:\Autodesk\WI\Autodesk Revit 2014\x64\en-us\RVT2014\RVT2014.mst;C:\Users\user\AppData\Local\Temp\_AI5D7D.tmp\x64\RVT2014\RVT2014-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/2/28:10:57:43    user    USER-PC    Install    Autodesk® Revit® 2014    Succeeded
2014/2/28:10:57:43    user    USER-PC    Download    Skipped    RVT2014_en-us    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/RVT2014_x64_...
2014/2/28:10:57:44    user    USER-PC    Installing Autodesk® Revit® 2014 Language Pack:  TRANSFORMS="C:\Users\user\AppData\Local\Temp\_AI5D7D.tmp\_laA6B2.tmp.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;" MUIHIDEARP=1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/2/28:10:58:09    user    USER-PC    Install    Autodesk® Revit® 2014 Language Pack    Succeeded
2014/2/28:10:58:09    user    USER-PC    Installing Autodesk Workflows 2014:   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/2/28:10:58:17    user    USER-PC    Install    Autodesk Workflows 2014    Succeeded
2014/2/28:10:58:17    user    USER-PC    Download    Skipped    CMILL2014    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/CMILL2014.ta...
2014/2/28:10:58:17    user    USER-PC    Installing Autodesk Material Library 2014 - Low Image Library:   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),{644F9B19-A462-499C-BF4D-300ABC2A28B1},;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/2/28:10:58:55    user    USER-PC    Install    Autodesk Material Library 2014 - Low Image Library    Succeeded
2014/2/28:10:58:55    user    USER-PC    Download    Play    CMILM2014    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/CMILM2014.ta...
2014/2/28:10:59:28    user    USER-PC    Download Error    CMILM2014    <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now?     http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/CMILM2014.ta...
2014/2/28:10:59:38    user    USER-PC    Download Error    CMILM2014    <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now?     http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/CMILM2014.ta...
2014/2/28:11:03:58    user    USER-PC    Download    Aborted    CMILM2014    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/CMILM2014.ta...
2014/2/28:11:03:58    user    USER-PC    Install    Autodesk Material Library 2014 - Medium Image Library    Failed    Download Failed, Installation aborted, Result=1603
2014/2/28:11:04:26    user    USER-PC    Rollback    Autodesk Material Library 2014 - Low Image Library    Succeeded
2014/2/28:11:04:30    user    USER-PC    Rollback    Autodesk Workflows 2014    Succeeded
2014/2/28:11:04:42    user    USER-PC    Rollback    Autodesk® Revit® 2014 Language Pack    Succeeded
2014/2/28:11:07:59    user    USER-PC    Rollback    Autodesk® Revit® 2014    Succeeded
2014/2/28:11:07:59    user    USER-PC    Rollback    DirectX® Runtime    Failed    Failure is ignored, Result=1619
2014/2/28:11:07:59    user    USER-PC    PageOpen    InstallCompleteDialog
2014/2/28:11:11:05    user    USER-PC    === Setup ended ===
2014/2/28:11:13:35    user    USER-PC    === Setup started on USER-PC by user ===
2014/2/28:11:13:35    user    USER-PC    Path_Length: 149
2014/2/28:11:13:35    user    USER-PC    Current Directory C:\Autodesk\Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US
2014/2/28:11:13:35    user    USER-PC    Launch
2014/2/28:11:13:35    user    USER-PC    CommandLine    /url "http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US_S... /akamai /auth authparam /sid SESSION_ID
2014/2/28:11:13:35    user    USER-PC    Current Directory C:\Users\user\AppData\Local\Temp\_AI2992.tmp
2014/2/28:11:13:42    user    USER-PC    === Setup ended ===
2014/2/28:11:13:36    user    USER-PC    === Setup started on USER-PC by user ===
2014/2/28:11:13:36    user    USER-PC    Path_Length: 149
2014/2/28:11:13:36    user    USER-PC    Current Directory C:\Users\user\AppData\Local\Temp\_AI2992.tmp
2014/2/28:11:13:36    user    USER-PC    Launch
2014/2/28:11:13:42    user    USER-PC    Download    Skipped    SETUP_CONFIG    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/SETUP_x64.ta...
2014/2/28:11:13:42    user    USER-PC    Install    CustomCallback    Info    Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\user\AppData\Local\Temp\_AI2992.tmp\Setup\RevitSetup.dll
2014/2/28:11:13:42    user    USER-PC    Install    CustomCallback    Info    Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/2/28:11:13:42    user    USER-PC    PageOpen    LaunchDialog
2014/2/28:11:13:46    user    USER-PC    PageOpen    LicenseDialog
2014/2/28:11:13:51    user    USER-PC    PageOpen    ProductInfoDialog
2014/2/28:11:14:49    user    USER-PC    PageOpen    ProductSelectionDialog2
2014/2/28:11:14:55    user    USER-PC    PageOpen    FullProgressDialog
2014/2/28:11:14:56    user    USER-PC    Download    Skipped    DIRECTX    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/DIRECTX.tar....
2014/2/28:11:14:56    user    USER-PC    Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2014/2/28:11:15:29    user    USER-PC    Install    DirectX® Runtime    Succeeded
2014/2/28:11:15:29    user    USER-PC    Download    Skipped    RVT2014    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/RVT2014_x64....
2014/2/28:11:15:30    user    USER-PC    Installing Autodesk® Revit® 2014:  TRANSFORMS="C:\Autodesk\WI\Autodesk Revit 2014\x64\en-us\RVT2014\RVT2014.mst;C:\Users\user\AppData\Local\Temp\_AI2992.tmp\x64\RVT2014\RVT2014-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/2/28:11:23:22    user    USER-PC    Install    Autodesk® Revit® 2014    Succeeded
2014/2/28:11:23:22    user    USER-PC    Download    Skipped    RVT2014_en-us    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/RVT2014_x64_...
2014/2/28:11:23:23    user    USER-PC    Installing Autodesk® Revit® 2014 Language Pack:  TRANSFORMS="C:\Users\user\AppData\Local\Temp\_AI2992.tmp\_la220A.tmp.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;" MUIHIDEARP=1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/2/28:11:23:43    user    USER-PC    Install    Autodesk® Revit® 2014 Language Pack    Succeeded
2014/2/28:11:23:44    user    USER-PC    Installing Autodesk Workflows 2014:   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/2/28:11:23:49    user    USER-PC    Install    Autodesk Workflows 2014    Succeeded
2014/2/28:11:23:49    user    USER-PC    Download    Skipped    CMILL2014    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/CMILL2014.ta...
2014/2/28:11:23:49    user    USER-PC    Installing Autodesk Material Library 2014 - Low Image Library:   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),{644F9B19-A462-499C-BF4D-300ABC2A28B1},;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/2/28:11:24:22    user    USER-PC    Install    Autodesk Material Library 2014 - Low Image Library    Succeeded
2014/2/28:11:24:22    user    USER-PC    Download    Play    CMILM2014    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/CMILM2014.ta...
2014/2/28:11:25:27    user    USER-PC    Download Error    CMILM2014    <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now?     http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/CMILM2014.ta...
2014/2/28:11:32:05    user    USER-PC    Download    Aborted    CMILM2014    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/CMILM2014.ta...
2014/2/28:11:32:05    user    USER-PC    Install    Autodesk Material Library 2014 - Medium Image Library    Failed    Download Failed, Installation aborted, Result=1603
2014/2/28:11:32:35    user    USER-PC    Rollback    Autodesk Material Library 2014 - Low Image Library    Succeeded
2014/2/28:11:32:39    user    USER-PC    Rollback    Autodesk Workflows 2014    Succeeded
2014/2/28:11:32:50    user    USER-PC    Rollback    Autodesk® Revit® 2014 Language Pack    Succeeded
2014/2/28:11:35:46    user    USER-PC    Rollback    Autodesk® Revit® 2014    Succeeded
2014/2/28:11:35:46    user    USER-PC    Rollback    DirectX® Runtime    Failed    Failure is ignored, Result=1619
2014/2/28:11:50:25    user    USER-PC    === Setup started on USER-PC by user ===
2014/2/28:11:50:25    user    USER-PC    Path_Length: 149
2014/2/28:11:50:25    user    USER-PC    Current Directory C:\Autodesk\Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US
2014/2/28:11:50:25    user    USER-PC    Launch
2014/2/28:11:50:25    user    USER-PC    CommandLine    /url "http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US_S... /akamai /auth authparam /sid SESSION_ID
2014/2/28:11:50:25    user    USER-PC    An instance of setup is already running. Only one instance of setup can run at a time.2014/2/28:11:50:39    user    USER-PC    === Setup ended ===
2014/2/28:11:35:48    user    USER-PC    PageOpen    InstallCompleteDialog
2014/2/28:11:50:47    user    USER-PC    === Setup ended ===
2014/2/28:11:53:22    user    USER-PC    === Setup started on USER-PC by user ===
2014/2/28:11:53:22    user    USER-PC    Path_Length: 149
2014/2/28:11:53:22    user    USER-PC    Current Directory C:\Autodesk\Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US
2014/2/28:11:53:22    user    USER-PC    Launch
2014/2/28:11:53:22    user    USER-PC    CommandLine    /url "http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US_S... /akamai /auth authparam /sid SESSION_ID
2014/2/28:11:53:22    user    USER-PC    Current Directory C:\Users\user\AppData\Local\Temp\_AI956F.tmp
2014/2/28:11:53:26    user    USER-PC    === Setup ended ===
2014/2/28:11:53:23    user    USER-PC    === Setup started on USER-PC by user ===
2014/2/28:11:53:23    user    USER-PC    Path_Length: 149
2014/2/28:11:53:23    user    USER-PC    Current Directory C:\Users\user\AppData\Local\Temp\_AI956F.tmp
2014/2/28:11:53:23    user    USER-PC    Launch
2014/2/28:11:53:24    user    USER-PC    Download    Skipped    SETUP_CONFIG    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/SETUP_x64.ta...
2014/2/28:11:53:25    user    USER-PC    Install    CustomCallback    Info    Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\user\AppData\Local\Temp\_AI956F.tmp\Setup\RevitSetup.dll
2014/2/28:11:53:25    user    USER-PC    Install    CustomCallback    Info    Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/2/28:11:53:26    user    USER-PC    PageOpen    LaunchDialog
2014/2/28:11:53:29    user    USER-PC    PageOpen    LicenseDialog
2014/2/28:11:53:36    user    USER-PC    PageOpen    ProductInfoDialog
2014/2/28:11:54:24    user    USER-PC    PageOpen    ProductSelectionDialog2
2014/2/28:11:54:30    user    USER-PC    PageOpen    FullProgressDialog
2014/2/28:11:54:31    user    USER-PC    Download    Skipped    DIRECTX    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/DIRECTX.tar....
2014/2/28:11:54:31    user    USER-PC    Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2014/2/28:11:55:00    user    USER-PC    Install    DirectX® Runtime    Succeeded
2014/2/28:11:55:01    user    USER-PC    Download    Skipped    RVT2014    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/RVT2014_x64....
2014/2/28:11:55:01    user    USER-PC    Installing Autodesk® Revit® 2014:  TRANSFORMS="C:\Autodesk\WI\Autodesk Revit 2014\x64\en-us\RVT2014\RVT2014.mst;C:\Users\user\AppData\Local\Temp\_AI956F.tmp\x64\RVT2014\RVT2014-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/2/28:12:01:51    user    USER-PC    Install    Autodesk® Revit® 2014    Succeeded
2014/2/28:12:01:52    user    USER-PC    Download    Skipped    RVT2014_en-us    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/RVT2014_x64_...
2014/2/28:12:01:53    user    USER-PC    Installing Autodesk® Revit® 2014 Language Pack:  TRANSFORMS="C:\Users\user\AppData\Local\Temp\_AI956F.tmp\_la5F0A.tmp.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;" MUIHIDEARP=1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/2/28:12:02:05    user    USER-PC    Install    Autodesk® Revit® 2014 Language Pack    Succeeded
2014/2/28:12:02:05    user    USER-PC    Installing Autodesk Workflows 2014:   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/2/28:12:02:09    user    USER-PC    Install    Autodesk Workflows 2014    Succeeded
2014/2/28:12:02:09    user    USER-PC    Download    Skipped    CMILL2014    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/CMILL2014.ta...
2014/2/28:12:02:09    user    USER-PC    Installing Autodesk Material Library 2014 - Low Image Library:   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),{644F9B19-A462-499C-BF4D-300ABC2A28B1},;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/2/28:12:02:33    user    USER-PC    Install    Autodesk Material Library 2014 - Low Image Library    Succeeded
2014/2/28:12:02:33    user    USER-PC    Download    Play    CMILM2014    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/CMILM2014.ta...
2014/2/28:12:03:50    user    USER-PC    Download Error    CMILM2014    <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now?     http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/CMILM2014.ta...
2014/2/28:12:11:41    user    USER-PC    Download    Aborted    CMILM2014    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/CMILM2014.ta...
2014/2/28:12:11:41    user    USER-PC    Install    Autodesk Material Library 2014 - Medium Image Library    Failed    Download Failed, Installation aborted, Result=1603
2014/2/28:12:12:44    user    USER-PC    Rollback    Autodesk Material Library 2014 - Low Image Library    Succeeded
2014/2/28:12:12:46    user    USER-PC    Rollback    Autodesk Workflows 2014    Succeeded
2014/2/28:12:13:00    user    USER-PC    Rollback    Autodesk® Revit® 2014 Language Pack    Succeeded
2014/2/28:12:16:58    user    USER-PC    Rollback    Autodesk® Revit® 2014    Succeeded
2014/2/28:12:16:59    user    USER-PC    Rollback    DirectX® Runtime    Failed    Failure is ignored, Result=1619
please help me out... tried so many times still not working for me ..
2 REPLIES 2
in reply to: bobojj
Try downloading Revit 2014 first and then running the installation. Go to http://www.autodesk.com/products/autodesk-revit-family/free-trial and scroll down to the Desktop Trial. Select the language and OS. Agree to the privacy notice and when the 'INSTALL NOW' button activates click on the down arrow next to it and select 'Browser Download'. Save the file to your local drive. When done downloading then run the installation.
Hope this helps.
Alex
dembkod
in reply to: bobojj
bobojj
Hello. You look like you may be failing on both the download and the C++ redistributables. I would uninstall all C++ redistributables on the machine and instead of running an “Install Now”, use the “browser download” option to get the full program for install.
Thank you for taking part in our community!
David Dembkoski
Administrator Productivity
