I am getting a 1,5,-15 error when trying to access the network license manger below are the specs of what I am running
1. Client PC Windows XP SP2 x64
2. Host Windows Server 2003
I am able to ping the host PC using IP & host name & vice versa, I have tried the 'Flexlm' timeout fix no go, I have checked the license file confirmed that the server name is correct & does not look like any changes have been done to it. Could Anyone provide any ideas that might work as I had logged a call only to be told 3 days later to use the forums
Hi:
You may find available resolution through the following link:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=3003046&linkID=9240617
Should you continue to receive error, provide us the details and your serial number through private message (envelope next to your account name at the top of this page) so we may research further.
Thanks!
