I have installed Vault 2011 on several clients. On two of the clients, the Vault 2011 is not shown under the add/remove programs. I need to do a repair install on these two clients. How do I get it to show in this list?
Solved by karthur1. Go to Solution.
I have a different machine that has a similar problem. When I right click on the Vault 2011 in the Add/Remove programs, I get the attached image
"An error occurred while trying to uninstall Autodesk Vault 2011 (Client)....."
I would like to either uninstall /reinstall or repair Vault 2011. Any ideas on how to do it would really be appreciated.
Found a silent uninstaller for Inventor 2010/11 here
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=14893355&linkID=9242018
This is a lifesaver.
