While I'm installing vasari beta 3, I keep having an error message. Could you tell me the solution for the error?
I enclosed the installation log file below.
Thank you.
2014/9/12:15:10:10 xxxxxxx === Setup started on xxxxxxx by xxxxxxx ===
2014/9/12:15:10:10 xxxxxxx Path_Length: 155
2014/9/12:15:10:10 xxxxxxx Current Directory C:\Users\PETERH~1\AppData\Local\Temp\_AI9B0.tmp
2014/9/12:15:10:10 xxxxxxx Launch
2014/9/12:15:10:11 xxxxxxx Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/FRMIT/20130926_1200/WI/{3F0BA818-59DA-40A0-8F09-F3E981A9BD...
2014/9/12:15:10:11 xxxxxxx Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\PETERH~1\AppData\Local\Temp\_AI9B0.tmp\Setup\RevitSetup.dll
2014/9/12:15:10:11 xxxxxxx Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/9/12:15:10:12 xxxxxxx PageOpen LaunchDialog
2014/9/12:15:10:21 xxxxxxx PageOpen LicenseDialog
2014/9/12:15:10:21 xxxxxxx PageOpen ProductInfoDialog
2014/9/12:15:10:21 xxxxxxx PageOpen ProductSelectionDialog2
2014/9/12:15:10:24 xxxxxxx PageOpen FullProgressDialog
2014/9/12:15:10:25 xxxxxxx Download Skipped DIRECTX http://trial2.autodesk.com/SWDLDNET3/2014/FRMIT/20130926_1200/WI/{3F0BA818-59DA-40A0-8F09-F3E981A9BD...
2014/9/12:15:10:25 xxxxxxx Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Vasari Beta 3\3rdParty\DirectX\DXSETUP.exe" /silent
2014/9/12:15:10:36 xxxxxxx Install DirectX® Runtime Succeeded
2014/9/12:15:10:36 xxxxxxx Download Skipped VAS2014 http://trial2.autodesk.com/SWDLDNET3/2014/FRMIT/20130926_1200/WI/{3F0BA818-59DA-40A0-8F09-F3E981A9BD...
2014/9/12:15:10:36 xxxxxxx Installing Autodesk® Vasari Beta 3: TRANSFORMS="C:\Autodesk\WI\Autodesk Vasari Beta 3\x64\en-us\VAS2014\VAS2014.mst;C:\Users\PETERH~1\AppData\Local\Temp\_AI9B0.tmp\x64\VAS2014\VAS2014-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Vasari Beta 3" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/9/12:15:10:36 xxxxxxx Install Autodesk® Vasari Beta 3 Failed Installation aborted, Result=1618
2014/9/12:15:10:37 xxxxxxx Rollback DirectX® Runtime Failed Failure is ignored, Result=1618
Solved by ukdxb012. Go to Solution.
Solved by dgorsman. Go to Solution.
Is this for a BETA test? Public forums are *not* appropriate places to be discussing BETA releases.
i need any link to download
vasari beta 2 or 3 any one is ok please....
