Installation & Licensing
Autodesk Usernames and Passwords
1 REPLY 1
RFreund
473 Views, 1 Reply
Can someone give me an overview of the different Usernames and Passwords or logins I shoud say, that are available with Autodesk. Is there anyway to have just one autodesk account?
For example:
I have a login for Autodesk disscussion groups, a login for the licenses tranfer utility, a login for the subscription center, a login for autodesk 360.
Which of these are the same, which are different? ( I don't use them enough to know which are the same and also I use lastpass so I don't need to remember them)
Also I just switched companies and used to have an autodesk subscription center login with that company. Do I now need a different login at the new company? How should this work?
Thanks!
www.HowToEngineer.com
1 REPLY 1
camilo.lemos
in reply to: RFreund
Hi RFreund.
This solution should give you a good idea of how the Autodesk Single Sign On system works.
Regarding your Subscription Center login, you will be able to keep the same UserID and password but you will need to have your contract and product information reflected to the new company (that is, if the new company has a subscription contract with Autodesk). What you would need to do in this case is have the contract manager from the previous company remove you from their contract and have the contract manager of the new company add you to their subscription contract.
Please, let me know if you have any additional questions regarding the information above.
Camilo Lemos
Administrator Productivity
